Results 1 to 20 of 23
    16,669
    Default New one off build . . .
    Well, I cut a couple of 1cf MTM PE baffles to accept a rear mounted TB 75-1558SE, along with the Peerless 830884 and SEAS 22TFF. Ryan (DoubleTap) and I then cut a chamfer/roundover on the front of the baffle for the TB mid, and took some sweeps of the drivers.
    I cannot believe that Peerless woofer is NLA. That thing has really excellent performance, with very low distortion top to bottom. 1% peak around 800Hz and the rest well below .3%, all the way down to below 100Hz. The TB mid, from 600Hz on up has vanishingly low levels of THD, and that particular mounting scheme provides for a response that looks like it already has a bandpass filter applied. It is very well behaved. Same thing can be said for the SEAS tweeter. Above 2000Hz, a very low distortion, very smooth responding tweeter. With the crossover targets we have in mind, this thing should be amplifier-like in its linearity.
    I suppose the HDS woofer could make an adequate substitute for the 830884, which would allow for others to make this project. But the cost of that mid might be a bit prohibitive for some . . .
    Schumakubin Plans
    The Fraud Continues || Hoax
    Oct 2009
    Little Rock
    394
    Default Re: New one off build . . .
    How about using the cam558 which is on sale right now instead?
    779
    1) Pics, or it didn't happen.
    2) If the Morel mid has a Neo motor, it's likely to become as unfeasible as the Tang Band very shortly.
    3) A lot of Tymphany's recent decision-making around the Peerless brand (such as discontinuing all use of Nomex/paper, and not bringing the non-truncated frame into wider production use) doesn't make sense to me.
    Best Regards,
    Rory Buszka
    Taterworks Audio
    16,669
    We used what was on hand, and the TB mid was tops on the list to get used in something.
    No plans on using a 2" dome mid.
    Mounted the way it is, with the flange hidden, that 3" dome has a real engaging quality on the baffle. Your eyes are definitely drawn to it due to the unusual look.
    Pics will come soon enough.
    Schumakubin Plans
    Jan 2010
    St Louis, MO
    943
    Booya! Great looking speaker if you ask me.
    Aug 2010
    Ft. Bliss/El Paso, TX
    912
    *like*
    Jan 2010
    North
    851
    That looks like a heck of a nice speaker! That 830884 sure is one nice woofer...
    I assume that it is a sealed cabinet based on the size. Try putting it in a ported tower, it can make some surprisingly nice bass as well.
    16,669
    Quote Originally Posted by dcibel View Post
    It's the PE 1cf MTM cabinet, and it is ported at the moment, though hardly optimized for that particular woofer.
    Schumakubin Plans
    Jan 2010
    St Louis, MO
    943
    In this size cabinet it can do F3 of about 42hz, but the F10 is around 26hz so it's a pretty slow rolloff.
    Bremerton, WA
    920
    Any thoughts on the sound of the 22TFF?
    16,669
    Quote Originally Posted by bmaupin View Post
    Just ran sweeps so far with the tweeter. No music yet. We did run both the mid and woofer with music full range though. Interesting . . .
    A preliminary XO was modeled up, but has yet to be wired up for listening.
    The potential for that tweeter is high. Very smooth response and low distortion above 2500Hz.
    Schumakubin Plans
    Sep 2010
    Laurel Hill, FL
    3,395
    Ooh that's sexy. good work.
    रेतुर्न तो थे स्रोत
    return to the source
    Wait, what? Peerless is disco'ing the Nomex stuff?
    Nice build Pete, love the recessed mid.
    Facebook
    *Gort
    Feb 2008
    Columbus
    1,895
    5
    Kinda similar to this speaker:
    The 830884 has been for a while - last time I checked Madisound said they could get more but you have to order in quantity.
    You can still get this similar woofer : http://www.parts-express.com/pe/show...umber=264-1098
    Feb 2009
    Tampa, FL
    894
    Just wondering... is that 830884 the same as the 830883 but with a truncated frame? I've got a build on the go that's using the 830883 and it looks like serious business but I haven't had a chance to hear it yet.
    16,669
    Quote Originally Posted by Ryan_M View Post
    the 883 is the 7" version.
    Schumakubin Plans
    Aug 2006
    Columbia, MO
    440
    PE had great pricing on Peerless when they started handling the entire line but something must have happened and their prices are much higher than Madisound now.
    I was tired and got tired again so now I am Re tired.
    Aug 2006
    Columbia, MO
    440
    I spoke too soon without checking. Madisound is now high too.
    16,669
    Finally getting back to this one. Took a set of sweeps in room. 6th octave smoothing.
    I hope to progress pretty quickly on these.
    The smoothness of response exhibited by the SEAS 22TFF is pretty remarkable. Distortion in the range of operation of each driver is equally impressive.
    I think I'll target the 350Hz woofer SPL for the overall system sensitivity.
    Now I get to go play with the FRD and ZMA in PCD.
    Who's a happy boy???
    I'm a happy boy!!!
    Schumakubin Plans
    16,669
    Here's what I was able to come up with using 13 parts, including 6 resistors for L-pads and zobels. Now I only have to figure out what I don't have on hand and put in an order.
    Schumakubin Plans
