Results 1 to 5 of 5
    Default 12 Dvc 295-185 T/s
    I have a 12 DVC from years back that I wanted put back into service. Using LIMP I measured the T/S specs and here are results:
    Fs = 20.87 Hz
    Re = 2.82 ohms[dc]
    Le = 5275.73 uH
    L2 = 2569.62 uH
    R2 = 35.58 ohms
    Qt = 0.37
    Qes = 0.38
    Qms = 8.16
    Mms = 211.34 grams
    Rms = 3.396924 kg/s
    Cms = 0.000275 m/N
    Vas = 93.15 liters
    Sd= 490.87 cm^2
    Bl = 14.260575 Tm
    ETA = 0.21 %
    Lp(2.83V/1m) = 89.89 dB
    Closed Box Method:
    Box volume = 62.00 liters
    Diameter= 25.00 cm
    Coils in parallel
    My specs are a fair bit off of published. Has anyone else come up with similar numbers or am I out to lunch? The plan was to use a SBB4 alignment and my numbers dictate a box size .75cuft less than the published specs.
    Default Re: 12 Dvc 295-185 T/s
    I used a WT2 and my results are similar in many places , these are my "115g mass added" results.
    Fs= 19.11 Hz
    Qms= 10.77
    Qes= .319
    Qts= .310
    Re= 2.63 ohm
    Le= 1.87mH
    Vas= 116.8L
    Bl= 14.33
    Mms= 207 g
    Sens= 90.7 dB
    Thanks Ryan !
    5,955
    Quote Originally Posted by deant View Post
    Fs = 20.87 Hz
    Re = 2.82 ohms[dc]
    Le = 5275.73 uH
    L2 = 2569.62 uH
    R2 = 35.58 ohms
    Qt = 0.37
    Qes = 0.38
    Qms = 8.16
    Mms = 211.34 grams
    Rms = 3.396924 kg/s
    Cms = 0.000275 m/N
    Vas = 93.15 liters
    Sd= 490.87 cm^2
    Bl = 14.260575 Tm
    ETA = 0.21 %
    Closed Box Method:
    Diameter= 25.00 cm
    Coils in parallel
    For your specs I'm guessin' it'll reach mid 20's in about 2.7 cf vented.
    For deant's I get upper 20's in just under 1.9 cf.
    For a pair I got quite a few yrs ago, I was getting more like mid 30's in about 3.5 cf. Yikes! Wish I had either of yours.
    If my design turns out I will post the results. I want to try an active assist with SBB4 alignment. I did a quattro 12 like this and the result was completely astounding. Given the boost levels used at such low frequencies the textbooks say it should have destroyed itself within minutes at anything above moderate volumes. In practice it doesn't even come close to its excursion limits with a dayton 240 watt amp, 6 months and still going strong. If the same design type works on the dvc it should be a keeper.
