Results 1 to 6 of 6
    Default SB Acoustics SW26DAC76-4 Shallow Subwoofer Klippel Test
    See original post here for full PDF report:
    http://www.diymobileaudio.com/forum/...ppel-test.html
    Quote Originally Posted by bikinpunk View Post
    Full report attached as PDF.
    I borrowed this driver from a friend who has yet to use it. The driver was tested on the same baffle all drivers I test are. Luckily, the baffle accommodates up to 10" drivers.
    The data you see is a bit perplexing when compared to mfg "linear xmax" values, but IMO, the fact that Cms is the most limiting value could be an indication of it needing a small enclosure; which logic tells you anyway given the fact that it's a small sub designed for a small enclosure. Additionally, the forward offset is so great, it surely must be a design characteristic (at least, I'd hope) and I'm curious what the reason for this could be. I'd like to build a small box, mfg recommended size, to see what the effect on the results are. But, since all my testing is done in dipole fashion I must present this data in the same way I do all my other tests. So, my warning with this data is this: I do not know of any other 'shallow mount' woofers being tested with the Klippel and therefore, AFAIK, this is the first type of this kind of woofer to have results published for all to see. Let's try to consider the implications of the data before jumping to any immediate conclusions. IOW, let's discuss rather than brand.
    Also, I want to note two things about this test:
    1. First off, I was unable to resolve Bl. I pushed this driver as far as I feel comforatable doing. In fact, I pushed the suspension as hard as the Klippel would let me (25% protection on Cms) in three tests and never was able to resolve Bl.
    2. Note the laxed distortion limiting percentages. I'm using these values as a 20% overall distortion set; which I've seen done in VC and I've discussed with Patrick. Providing overall 10% distortion parameters (82% Bl, 75% Cmin) is as easy as punching these numbers in to the test file so I can provide that should you guys feel that data set is more applicable.
    Link to Driver:
    http://www.madisoundspeakerstore.com...bwoofer-4-ohm/
    Measured T/S Parameters:
    • Re = 3.1674 ohms
    • Fs = 24.1651 Hz
    • Zmax = 42.4726 ohms
    • Qes = 0.5582
    • Qms = 6.9271
    • Qts = 0.5166
    • Le = 0.7881 mH (at 1 kHz)
    • Diam = 207.0100 mm ( 8.1500 in )
    • Sd =33656.7797 mm^2( 52.1681 in^2)
    • Vas = 54.6781 L ( 1.9309 ft^3)
    • BL = 10.4873 N/A
    • Mms = 127.6607 g
    • Cms = 339.7849 uM/N
    • Kms = 2943.0386 N/M
    • Rms = 2.7982 R mechanical
    • Efficiency = 0.1299 %
    • Sensitivity= 83.1532 dB @1W/1m
    • Sensitivity= 87.1771 dB @2.83Vrms/1m
    Klippel Linear Xmax Values:
    • X Bl @ Bl min=70% >8.5 mm
    • X C @ C min=50% 6.6 mm
    Sample Data:
    Pictures from phone:
    16,604
    Default Re: SB Acoustics SW26DAC76-4 Shallow Subwoofer Klippel Test
    Looks like its suspension is tailor made for horizontal mounting.
    Perhaps a down-firing application for most suspension linearity.
    Or do I have that backward?
    Schumakubin Plans
    The Fraud Continues || Hoax
    I am the first to admit that Klippel testing is awesome, but so is my ignorance of the test results on the awesome level. Near as I can tell, the center line of the charts indicates a driver at rest? And the rest of the chart shows linearity of the driver on either side of zero?
    Facebook
    *Gort
    Jun 2009
    Northern NJ
    345
    This, in my opinion, is not what you'd want to see from a $380 driver. Symmetry on all curves lies 4-6mm out.
    Dec 2008
    Long Island
    2,581
    IIRC, it used to only cost half that, before neo went through the roof.
    http://www.diy-ny.com/
    Quote Originally Posted by Face View Post
    That is true. IIRC, this driver was in the $200 range before it jumped up substantially.
