Results 1 to 5 of 5
    MD
    216
    Default HDMI commerical cable ratings CL2P vs CL3P
    Does anyone know the differences between CL2P and CL3P hdmi cables?
    The P indicates it's for use in plenum spaces. (ex: a plenum ceiling is typically when the space between the ceiling tiles and above slab is used as a return duct for the HVAC system, the plenum rating helps reduce toxic gases from being spread thruout the building.
    Jun 2009
    OH
    213
    Default Re: HDMI commerical cable ratings CL2P vs CL3P
    As far as I know CL@ is rated to 150V and CL3 is rated up to 300V
    MD
    216
    Thanks Johnnycat
    BTW Here's a NEC substitution chart by Carol cable thats made by General cable.
    http://www.alliedelec.com/images/Pro...ubstitChrt.pdf
    CL2 is for class 2 circuits, CL3 is for class 3 circuits:
    http://ecmweb.com/mag/electric_under...g_nec_circuit/
    MD
    216
    thanks feyz,
    That adds in understanding the difference between CL2 and CL3 which seems mostly related to how much voltage\power the cable can handle.
    That said I still haven't seen how to determine if a hdmi Cl3 rated cable is needed or required over a CL2 rated cable, since the hdmi standard seems limited to 5.3v volts.
    hdmi voltage specs in post #11 at
    http://www.avforums.com/forums/sky-h...cp-damage.html
    Last edited by mike s; 03-26-2012 at 09:45 PM. Reason: changed voltage rating from .6 to 5.3v
