Results 1 to 20 of 21
Thread: New Test CD
    Nov 2010
    Erie, PA
    228
    Default New Test CD
    Was wondering does anyone know if the new test cd is available or if there is a date when it will be?
    Jeff
    Jan 2010
    North
    839
    Default Re: New Test CD
    What new test CD? Where did you hear about this? What does it do that the current one doesn't?
    Nov 2010
    Erie, PA
    228
    My disc has only 4 tracks on it, the new one has 19 tracks.
    Test CD Track Listing
    (these are the tracks for the expanded Test Signals CD, to be available in 1st Qtr, 2012. The version 1 Test Signals CD contains only longer versions of the first four tracks)
    Track 1: Monophonic Pseudo-noise sequence
    Track 2: Monophonic Short Sine Sweep
    Track 3: Monophonic Long Sine Sweep
    Track 4: Monophonic Bass Sweep
    Track 5: Left Channel, Pseudo-noise sequence
    Track 6: Left Channel, Short Sine Sweep
    Track 7: Left Channel, Short Sine Sweep, bass removed
    Track 8: Left Channel, Short Sine Sweep, bass and midrange removed
    Track 9: Left Channel, Long Sine Sweep
    Track 10: Left Channel, Bass Sweep
    Track 11: Right Channel, Pseudo-noise sequence
    Track 12: Right Channel, Short Sine Sweep
    Track 13: Right Channel, Short Sine Sweep, bass removed
    Track 14: Right Channel, Short Sine Sweep, bass and midrange removed
    Track 15: Right Channel, Long Sine Sweep
    Track 16: Right Channel, Bass Sweep
    Track 17: Warning
    Track 18: Left Channel, 50 Hertz Tone for voltage measurement
    Track 19: Right Channel, 50 Hertz Tone for voltage measurement
    Jeff
    I knew there was a new cd coming but didn't realize how awesome it is goig to be.
    When you stop caring about being right, you might actually learn something.
    My test data site:
    http://medleysmusings.com/
    Jan 2010
    North
    839
    I guess I didn't realize there was an "old" CD. What you described with 19 tracks is what I have. I had no idea since it matched what was described in the help file. The Omnimic software also came with FRD's to compensate when using the high pass or bandpass sweeps.
    Dec 2008
    Long Island
    2,575
    So how does an early adapter acquire this CD?
    Any way PE could make it available for download?
    http://www.diy-ny.com/
    Quote Originally Posted by Face View Post
    I am quoting this from another post from Bill Waslo:
    Quote Originally Posted by bwaslo View Post
    Hi,
    I heard people were asking about the new test signal CD. If you want, you can download the wav files for it from here, for a while at least
    OmniMic%20Signal%20Test%20CD%203.zip
    But be warned -- it is a 251MB download, so it will take a while unless you have a really fast connection. Probably not likely to work on a phone connection.
    After downloading you'll have to:
    1) unzip it (it's a zip file)
    2) use a CD burn program (Nero, Sonic, etc.) to make an Audio CD Disk, select the files in the proper order (by their numbers) into it and be sure to burn with "normalization" turned OFF (if that option is given).
    Same signals as original CD, but there are Right-Only and Left-Only versions of most, as well as some bandlimited versions and a level-setting tone. See the last section of OmniMic Help (the menu in the program) to see the file listing.
    The 5.1 DVD isn't compiled yet. Enjoy,
    Bill
    Dec 2008
    Long Island
    2,575
    Thank you!
    (2 minute download)
    Thank you!
    (2 minute download)
    You're welcome Face...
    I am looking forward to the 5.1 DVD later this year.
    Dec 2008
    Long Island
    2,575
    It appears track #16 is corrupt.
    yep. noticed the same thing.
    My test data site:
    Jan 2010
    North
    839
    I got some error when extracing, but all the tracks are there and are fine, including #16.
    I could not download Track #16 so I skipped it in the download. All other tracks are there so what do I miss not having 16?
    Nov 2010
    Erie, PA
    228
    same problem with track 16 also
    Jeff
    5,732
    i just tried to download and the link sends me to 'FORBIDDEN'.
    The link is still active as I just DL the file again...
    5,732
    403 FORBIDDEN.
    would you send it to me in a e-mail?
    Nov 2010
    Erie, PA
    228
    arlis_1957, you might be able to get it this way. go to link then download Omnimic signal tect cd 3.zip.
    http://www.libinst.com/junk/
    Jeff
    5,732
    the link by bill is working on my laptop just fine. i'll jut burn it to cd later. thanks for the help.
    Smile Re: New Test CD
    OmniMic Audio Test Tracks are now available as a download (below) and
    also off the Dayton Audio website!
    Download the Omni_Mic_Test_Tracks.zip file
    Once you have downloaded the .ZIP file, unzip the file and burn the audio tracks to a CD using your favorite CD burning software.
