Faux Carbon Fiber OS MTMs
First off, thanks to Paul. He really hit one out of the park here. These little guys are amazing! Low end you can feel in your chest from a really modest size. Rich, detailed, well balanced sound. If you're on the fence about building a set I highly recommend them.
Anyway...
Started off as usual on the milling machine and rotary table:
Cut all the driver holes for flush mount and added a little roundover to the back edge of the woofer cutouts so those little HiVis can breathe:
Hurricane Nuts with a little polyurethane glue to hold them in place:
For the ports, I cut the tubes .250" short and then cut some flat-bottomed holes into the rear panel, leaving .250 of MDF to get to the 6" required length:
Glued them in place with some polyurethane glue and then trimmed off the excess with a flush-trim bit on the router table. I owe someone here thanks for this idea... wish I could remember who, but this is a great way to do PVC ports. Super easy:
Added a couple dowels for bracing... Bit of a bird's nest of wires around the crossover at this particular moment...
I really didn't feel like painting this time around. I was going to wrap the boxes in Tolex (like a guitar amplifier,) but I remembered I had a bunch of this fake carbon fiber kicking around. Unlike actual carbon fiber, the stuff is really easy to work with and actually looks the business. Anyway, I had bought a bunch that I never ended up using and I wanted a dark color to make those woofers pop a little, so it seemed like a good opportunity to use it up. This was also infinitely less effort than painting. I just stuck it all down with 3M Super77 and then carefully trimmed the excess with a sharp razor:
The front, back and sides are all one piece with the inevitable seam on the back panel:
One last shot of the flush-mount and fake carbon weave:
There is one strange thing going on, though... I have a bit less high-end coming out of one of the speakers than the other. I double checked the crossovers and they're both correct. Not really sure what's going on. It's really slight, but I can definitely hear it if I A-B them with a balance knob. Maybe I have a bum tweeter?
Anyway, thanks for looking!
Re: Faux Carbon Fiber OS MTMs
Looks great!!!! Where did you order that faux carbon fiber from?
Thanks. I picked it up on Ebay... I just tried digging through my history for the vendor link, but couldn't find it.
Those look fantastic. Good job! I like your attention to detail. you will enjoy those speakers for years to come and I agree with what you said about them.
Thanks! I'm sure it's something I can search for.
Nice work. They look great.
I agree... clever idea with the port.
Could you provide a tad more detail on how you get a perfect seam between the face, sides, and back against the top of the cabinet?
Do you do the top first, then the sides, or both at the same time and cut the excess?
Thanks!
X2 on the CF wrap, that's an exhalent look for those, BRAVO !!
I did the front, back and sides first, all one piece.
The wrap is cut pretty generously so that there's enough overhanging all of the edges and enough for it to overlap on the back side. The only real trick to it is overlapping the two loose ends on the back and cutting through them both at once. Then you peel them back and remove the two scraps leaving a nice, even seam.
The tutorial here gives a much better explanation with pics:
LINK
I then trimmed the excess off the top and bottom. I just used a new, sharp razor to cut them flush using the box edges themselves as the guide. I added the vinyl to the top and bottom last and trimmed the excess in the same way.
Congratulations on one of the cleanest looking OS MTM builds yet! That carbon fiber wrap is very svelte. Reminds me of a black panther w/ 2 copper eyes staring out at you.
Was this Di-NOC or the 1080 series or something else? Di NOC is EXPENSIVE......for my 5.0 project Di NOC is gonna run me ~$570...1080 series about $320....
Something else... Like I said I got it on eBay, but the transaction isn't in my purchase history and I can't recall the name of the vendor. However, i'm about 95% sure it was this stuff
LINK To auction
from this guy:
Link to vendor
I remember looking at the Di-NOC stuff. I ended up just buying real carbon fiber and resin... for about the same money.
Nice build
Some day I'm going to get a milling machine, the possibilities!
 Originally Posted by Mikers
Nice build
If you have the space they're a lot less $$ than you'd expect if you're patient and wait for the right deal to come along. You don't need 3-phase service to run one either. I'm running mine (which has a 3-phase motor) on a variable frequency drive that gives me the ability to run it on single-phase power and gives me true push-button variable speed from a J-head, which is pretty cool.
single-phase in, 3-phase out:
Very nice build, Mike. I appreciate the link for the CF. I picked some up last eve. $50 with free shipping for a 9' x 4.5' piece. Should look nice on my up-coming project.
I had a similar issue with a tweeter on my D8s. XO was good. Replaced the driver and it was fine. But yeah, it was a very slight difference, just didnt seem to go quite as high or loud.
Thanks so much for the info for the CF fabric! I have a couple of these that are just begging to be in a cabinet that looks just like yours.
No doubt about it. Those are hot!
