Page 1 of 3 123 LastLast
Results 1 to 20 of 52
    Sep 2010
    Canton, OH
    1,556
    Thumbs up Building 4 Dual 18 boxes, help needed and build thread
    Hey guys you know when I get on here and chat sometimes I like to pretend that I know everything but when it comes down to business and entering a new area I start having questions. I just got a client from a local venue that wants me to build him 4 Dual 18 boxes. He was originally talking to me about buying speakers from me to upgrade the ones in his current subs, but I successfully explained to him that's more or less going to be a waste of money since the boxes are more of the problem than anything. They're EV kickbins and Nady dual 15's The harmonic distortion from those subs when they're crankin' I believe exceeds the fundamental notes at times when I've heard them, I'm not even joking.
    We're going with 8 Eminence Definimax's. I'm already imagining these in the smallish room, it's going to be a major upgrade for them especially on dance tracks. He has to currently HP those subs pretty high so some of the fundamental subbass is non-existant in some of the dance music they play.
    Anyways the most obvious format to build these in is 2x18 boxes. I'm deciding whether to slot port the boxes on either end or just one giant rectangle port in the middle. Obviously bracing the back becomes and issue with the single giant rectangle port in the middle, it would have to be built into the port somehow. Which would you go with?
    Creedmoor, NC
    870
    Default Re: Building 4 Dual 18 boxes, help needed and build thread
    Hey guys you know when I get on here and chat sometimes I like to pretend that I know everything...
    Isn't that what the internet is for? I have never used the definimax, but it sure looks like a good driver.
    Just purely for aesthetics, I would use a slot port at each end. But that is very subjective. I have seen some cabs that use 2 triangular ports between the two woofs, seems a good ways to port it without making the cab any larger.
    Just to save BFM the time, why not a folded horn?
    5,706
    Quote Originally Posted by AMC View Post
    Probably because the client thinks there's something special about using eighteens. I know better, so I don't.
    North TX
    1,979
    Harder to build? Already has the drivers? The Definimax reportedly won't work well in a horn due to cone flex.
    But four 2x18's is definitely getting up to the 'critical mass' needed to get horns flat to 40.
    5,706
    Quote Originally Posted by wg_ski View Post
    Doesn't know any better. Not that 2x18s can't work well, but dollar for dollar and pound for pound horns crush them. They only have the advantage of smaller size, an advantage wiped out by the much higher power requirement.
    The main reason 2x18s remain popular is price, you can get them for under a grand, so they're ubiquitous. Commercial horns like Danley aren't widely seen because so few can afford them.
    Sep 2010
    Canton, OH
    1,556
    Brotha, I know folded horns are the way to go, the low harmonic distortion sounds so clean from them. You're gonna laugh but I really don't have the time or the budget to pay myself for labor to construct them in this deal. Either way this club is pretty small, I'd say the room is 1500 sq ft. 8 relatively low distortion 18's will get it pounding pretty hard. The other problem is that the ceiling in this place is real low, i'd say its like 9ft so the stage is only about 6 inches off the floor and the subs need to remain pretty low profile.
    Anyways I'm sure we're going to be satisfied with the results, it's going to be an upgrade from the EV kickbins and nady dual 15's for sure.
    Stittsville, Ontario
    1,969
    Yep.. four 15" loaded horns would create the same if not more output with a fraction of the input power, but of course the boxes are more complex to build and these would need to be co-located(clustered) to deliver that performance. And the customer may have an adversion to horns now despite the fact they have been using an old bass bin as a sub.. which we know isn't the same thing but you probably won't convince the customer of that.
    If you do build the dual 18s I like the look of a single central port though I'd actually design the boxes as mirror imaged seperates with the ports together in the middle, that way each driver is loaded seperately and can function independantly should the other die for whatever reason.
    Paul O
    Sep 2010
    Canton, OH
    1,556
    Quote Originally Posted by Paul O View Post
    You brought up a good point, in this room we can't have a single cluster, they HAVE to be on either side of the stage. It's a major drawback. Also good idea about having the subs loaded separately I'll try to work that into the design. Like I said unfortunately I am working on a relatively tight budget on this deal in terms of labor cost. The budget is also restricting me from using my typical ridiculous A+++++ quality baltic birch plywood so I'm going to have to incorporate some cheaper alternatives into these. Good thing they are more or less a permanent install.
    Sep 2010
    Canton, OH
    1,556
    Here's some pics of the venue. There's also a couple other things that could be better about their setup, like it would be more ideal for the stage to be at the long end of the room, but that's something that can't be changed.
    Sep 2010
    Canton, OH
    1,556
    Quote Originally Posted by amc View Post
    Just To Save Bfm The Time, Why Not A Folded Horn?
    Lol
    North TX
    1,979
    Look into using Araucoply - $40 a sheet. I used it to build the cabinets (not speaker) in my new shop and it was a PLEASURE to work with compared to low cost 'birch'. 5 solid plies (no veneer to peel off) and almost no voids at all. Good on both sides. I'll be using it for my next speaker builds.
    Sep 2010
    Canton, OH
    1,556
    I've seen that stuff at menards and I was relatively impressed with the way it looked from the outside. It did look like it would be better to work with than the cheap chinese birch which is something I'd like to avoid all together. I'll probably end up going with the araucoply and some MDF for bracing or the backs possibly.
    Did you do a round over on the araucoply? If so did it tear out at all? that's my biggest concern since I'm probably going to paint these boxes black I don't have to have to do a ton of 'body work'. Forgettabout it with that cheap chinese birch plywood, that stuff is a joke.
    North TX
    1,979
    Roundovers work much better on Araucoply than on cheap chinese birch. I went through SO MUCH BONDO it wasn't funny to fix tear outs on some chinese birch cabs I built. Funny thing is some of that cheap chinese stuff was actually decent and I had no trouble at all. But that batch is long gone.
    Sep 2010
    Canton, OH
    1,556
    Great! That's definitely what I'll be using. If I tried to use the $80/sheet plywood I normally get I would probably be in the hole on this deal. 4 dual 18's = lot of material. These boxes are going to be 48" wide x 22" tall by 30" deep or so
    Creedmoor, NC
    870
    If it's 'permanent' I would use as much MDF as I can. And Yes, 8 of those drivers are going to make some serious SPL.
    Nice place.
    Sep 2010
    Canton, OH
    1,556
    Nice place.
    Yeah I was thinking about MDF as well, although I severely loathe MDF dust. And thanks for being positive about it. He's only going to be pushing all the subs with only 2 crown microtech 2400's for now, so 400 watts to each driver? but that should still be enough to slam the room. I don't even think the Nady dual 15's he has hooked up now are even doing anything, and the EV kick bins fall off like a rock, I don't believe I've really felt a heavy 45hz or under note on any dance tracks with the current setup. That's about to change...
    Oct 2010
    Grand Blanc, MI
    737
    I'd love to get a job like that. I'm sure you'll be watching for the smile on your customers face the first time he hears them! I also don't like MDF, but if you are going to use it - don't for the braces. That stuff splits way to easy. I clamp it, no nails or screws. I have not seen Araucoply, but that sounds better.
    Sep 2010
    Canton, OH
    1,556
    Quote Originally Posted by duanebro View Post
    Oh yeah definitely! I think there's going to be smiles all around, especially since that room isn't very big there are going to be some notes that just shake your insides. I am mostly anticipating the sound quality improvement because his current subs sound quite muddy, it sounds like it rolls off dead below 60hz and the harmonic distortion is high. You don't really get that ultra deep rumbling bass that you need on the dance tracks they play on dance night there. These definimax's are going to be a bit underpowered, the positive side to that is at least they will have pretty low THD so the quality will be dyamite, but he will also have some headroom to add another pair of amps if he wants to juice it up even more, but I feel like that won't even be necessary.
    Yeah I only glue and clamp my cabinets. You probably haven't seen my other guitar cab build thread on here but I have pretty high standards for that stuff!
    I'll be using dowel braces for these guys, I'm probably not going too overboard with it but enough that should pass the 'knock test'.
    1,969
    Can't see the speakers clearly in the pics posted above so I processed one of them a little to get a better look. It appears you have some EV MTL-1s there with some other reflex bin on top of them. If so then yeah they're not really subs by todays standards(-3db at 50hz) even though EV continues to market them as such.. http://www.loyola.com/av/products/audio/ev-mtl1x.html. And I'm sure Bill and the others will comment on the position of the stacks way out from the wall and that far apart as not helping matters at all, and if the new subs are postioned the same you will still have problems with uneven bass coverage in the room and near complete cancellation of some frequencies.
    Paul O
    Sep 2010
    Canton, OH
    1,556
    Oh man I know. When he was first setting up the venue a year and a half ago he consulted me about the sound a bit. I told him if there's anyway to make one cluster of the subs that is the way to go. I am against having 'stereo subs' unless they're like 30 or 40ft apart on either side of a massive stage, that's the only time it makes sense.
    Unfortunately as you can see there is basically no other option for this venue the way it's setup. They have a lot of concerts there (that's mostly what they do) so with bands on the stage you can't put the subs up against the wall. I wish they had more ceiling height because he would have no problem with building a taller stage and putting the subs under it, which is the way to go. Have to work with what they have.
    From what I've heard the bass *is* spotty in areas. Moving around in places between the two 'sub stacks' gets some big comb filtering, on either side of the stage though (entirely off axis of the mains which is another issue) the bass is relatively uniform. It's hit or miss I mean live sound a lot of times IS a crap shoot unless you really put a lot of engineering and design behind the setup and the room itself. I'm fairly well educated on room acoustics. Still those subs he has need to go, it's time for an upgrade!
    PS - Yeah they are EV MTL-1x's. What those 'subs' are to me is a way for EV to utilize really cheap woofers safely, with the incredibly small enclosure volume to minimize xmax and market a crappy product to make some $$$. The other boxes on top of them are Nady Dual 15's. I have no words to the utter crap heap those are.
