Dual 12" + 2" Comp designs
Collapse
X
Re: Dual 12" + 2" Comp designs
Also, have not actually listened to them, but the new eminence IMPERO™ 12A looks real nice. Don't know what the price will be yet.
You should read more, comment less.Comment
I wouldn't use them in a cab that goes on a pole. They also need a low crossover, like 800Hz. A bit of an odd duck really, unless you really need an 1100w thermal rating.Comment
On a different thread, someone mentioned the Faital Pro 12PR300. Again I have not used it. But it sure specs out nice, albeit a bit pricy. Has anyone used any of the inexpensive B&C neo woofers? They look like a steal at times.
Comment
Comment
My Double 12 X 2 inch cabinets are the same basic concept as you looking at, 60 x 40 JBL 2385 horns, EV ND6x drivers and B&C 12 PE32 cones. For me that combination works well. Well braced, Sealed cabinets, non trapezoid.Mike Caldwell
http://www.mikecaldwellaudioproductions.comComment
Their graph shows them going out nicely to 3K, but I guess that is where a graph line has it's limitations. Looked like a nice mid bass but not if it only goes to 800.
http://www.parts-express.com/pe/show...number=294-694Comment
it appears there is really no good way to stack multiple speakers. in my situation i'll be using subs, either TH-18s or the CBEs (cyclops), and crossing them at 100hz (or somewhere in that neighborhood). i don't know if i would want to stack another 2-12 on top.
i put this together a while back. this concept seems to be presented with several issues. height, phase, etc. what do you guys think?Comment
But don't stack mains over subs. That's another practice encouraged by manufacturers even though they know it's wrong, pandering to make sales to consumers who don't know that.Comment
As to the design itself, not knowing the specifics, but be careful that the mids are not spaced too far from the woofs.Comment
As much as I agree in principle that vertical arrays are technically better than splayed horizontal arrays, I have to say I have heard many more bad sounding vertical arrays in the last 10 years than I did splayed stacks the 30 years before. Yes vertical arrays produce more horizontal coverage but it's debatable(IMO) if overall intelligibility is better, I don't remember every hearing so much comb filtering from the old stacks as I have from large scale line arrays.Paul OComment
when I saw the FooFighters last year in ATL, they had some flown arrays of about 10 stacks. Some were a bigger arc pointing down toward the floor and others were more subtle to the rest of house.
As near as I could tell, all the subs were under the stage.
After re-educating myself around here last year, I've made sure to corner load subs since, but after going to that show, hearing their setup, and noticing not one house speaker on the stage that I could see.... and then at the end of the night seeing them wheel out at least 12 cabs of dual 18s from underneath, drove home some of the fundamentals.Comment
This isn't just a marketing thing. The practical side is those subs make a good, stable base for the stack, much better then any pole system. And if you trying to be VERY portable, double use items (subs and speaker base) helps save room. I know it's not perfect, nothing is, but it's not without it's merits either.Brian Steele
www.diysubwoofers.orgComment
My experience is closer to yours Paul. I've heard examples of arrays that sound bad because they were not implemented correctly. Just as any system will sound bad if used/placed/operated incorrectly."Not a Speaker Designer - Not even on the Internet"
“Pride is your greatest enemy, humility is your greatest friend.”
"If the freedom of speech is taken away, then dumb and silent we may be led, like sheep to the slaughter."Comment
As much as I agree in principle that vertical arrays are technically better than splayed horizontal arrays, I have to say I have heard many more bad sounding vertical arrays in the last 10 years than I did splayed stacks the 30 years before.Comment
Comment
