Results 1 to 20 of 40
    new england
    964
    Default Introducing the "INTIMATES" (high WAF & quality sound)
    If you're getting a good tax refund this year and are in search of a high quality 'build' mini-monitor project, read on....
    About a year ago I became intrigued with a dated Stereophile review of what turned out to be the very popular Sonus Faber Extrema (SFE) loudspeaker. But it was Martin Colloms' preamble to the actual review that caught my attention. The crossover design, he explained, was extremely simple, but needed special drivers to be as successful as it eventually was. Just a resistor in series with the tweeter and two coils and no capacitor. At the time the xo design was called the "Sine-Cap". The design required a high wattage resistor and the production SFE sported a heat sink on the back of the cabinet. http://www.stereophile.com/standloudspeakers/915
    At the same time I discovered the Acoustic Reality series xo. It also had only 3 parts and again, no capacitor. http://arhifi.dk/store/product.php?id_product=22
    I decided to build (more correctly stated; assemble) two mini-monitors, one with the SFE xo and the other with the AR sxo so I could compare their measurements and sound. Each design resultd in a 1st order elect xo so I knew I needed to find some very good quality drivers that could handle the demands of those xo's. I eventually settled on a SS D2905/970000 tweeter and SS 15W/8530K 01 woofer mid which when coupled with a 1/2 cu. ft. vented box could easily get down to 40 hz. Not wanting to be bothered with constructing boxes, I decided on the attractive PE p/n 302-723 curved sided cherry 'finished' cabinets. The other critical consideration in the driver selection was that each had a relatively smooth extended FR.
    A BB drawing was created and when the cabinets arrived, I had 2 BB's professionally cut so each driver was flush mounted. Next, cabinets were assembled and drivers and wires from each were snaked out the back two holes that come pre-drilled in the cabinets. I set up my virtual xo box and started varying parts until each xo design measured and sounded quite nice. Sorry simmers; no PCD's to display. The xo's were arrived at totally empirically. Off axis response was also excellent (see link below)
    With the SFE design I still had the problem of dealing with the tweeter's series wired resistor and its power challenges and inherent heat dissipation. Then it hit me. I needed to install a vent (ended up 2" dia. X 9" long PE p/n 260-387). So, locating the resistor near the vent's internal mouth would naturally cool it by the air flow thru the vent. I decided on locating it high up on the back side behind the tweeter and selected Mundorf M-resist 20W resistor. They come with a convenient 1/4 in hole thru their center. I cut some 1/4 inch wood doweling and installed two pre-fabed wooden 'nests' on the inside cabinet sides to rest the dowel in a position that suspended the resitor right over the end of the vent tube.
    High quality coils were selected. A 3.0 mH, 15 ga. air coil for the woofer/mid and 14 ga. copper foil coils for the tweeter parallel coil. Being concerned about tweeter protection in the event of a DC surge, I decided to add a totally optional high value cap in series with the tweeter and settled on a 500 uF Bennic which didn't impact the already finalized xo topologies.
    After some extended listening with each xo in my somewhat reverbarent listening room, I decided on the SFE xo with it's small BBC dip response using 15 ohms for the series resistor. If you want a flatter response, you can try a 10 ohm resistor in place of the 15 ohm shown on the schematic. I haven't had much luck with it. Evidently, the 5 ohm reduction in series resistance is just enough to bring on ringing.
    In the meantime my wife saw the finished speakers and said "your keeping those aren't you?" So, they now reside in our living room where no speaker system has sat for many years since we first got married and I owned a HK compact stereo. Bass extension with these woofer mids in these vented cabs is surprisingly low and articulate. Reviews from fellow audio society members who've visited for extended listening sessions have been very positive.
    I decided to call these speakers the Intimates because they aren't designed for regular 95+ dB listening. They perform best with acoustic music and vocals from smaller groups. I have them on 26 inch high solid cherry stands located about 1 ft from the wall to take advantage of the vent's reflected output. Being a hugh fan of classical music, I also listen to symphonies with them as well. They hold their own, but obviously don't have the big, complimentary symphony sound you'd get from a much larger multi-driver speaker system.
    Below are a couple of teaser pics of the speakers and some measurements which some of you may have seen posted in other threads. Visit here for more detail pics of the internals, BB dwg and xo schematics. http://s1219.photobucket.com/albums/...ct%20pictures/
    Last edited by carlspeak; 03-23-2012 at 02:50 PM. Reason: Added 10 ohm resistor option
    Nov 2007
    Lil' Rhody
    3,210
    Default Re: Introducing the "INTIMATES" (high WAF & quality sound)
    Carl,
    Been following these for some time. Great build and a good challange. I doubt they sound any less than wonderful!
    5,745
    and his wife likes them.
    Jan 2011
    Colorado Springs, CO
    494
    Very nicely done Carl! I see why you were intrigued... Thanks for sharing--now I am intrigued too. Just what I need, another build to add to my already long list
    Jason
    "In my opinion, there are more tactful ways to state your opinion."
    Oct 2009
    Little Rock
    393
    I can't quite understand what you did with the dowling /resistor /vent. Pics?
    new england
    964
    Quote Originally Posted by 2leftthumbs View Post
    Go back to my photobucket album link. Double click on the top row middle pic. It will show the dowel being held in little wooden 'nest' blocks I glued to the sides of the cabinet walls. I picked a spot that has the resistor suspended about 1/2-3/4 inches above the mouth of the vent tube, but not too high to intefere with the tweeter magnet. I have a few more pics I could upload if need be.
    Jul 2007
    Phoenix
    3,169
    I know I'm going to feel pretty stupid when I see the answer, but what is a BB drawing?
    I really love the look of these, wish I could afford the drivers...
    Nice work!
    Mark
    I don't wanna live forever,
    And don't forget the joker!
    ~Lemmy
    new england
    964
    Quote Originally Posted by Mark65 View Post
    Nice work!
    Mark
    Sorry Mark for being criptic. BB=baffle board.
    17,579
    Looks reasonable, Carl!
    I almost did this with the Glucinium Amor MTM I did. I mapped out a sim, but didn't have the guts to try it out.
    Hope to hear yours one day...
    *InDIYana 2013 event*
    new england
    964
    Well, if you can make the CT. Audio Society Aug. mtg mini-monitor shoot out, you'll be able to. (www.ctaudio.org)
    How did you like those Dayton pre-built enclosures? I was contemplating them for my current build. Kind of wish I went with the pre-built enclosures because it's taken me a week just to build the enclosures, not to mention finish them.
    I decided to build the enclosures to custom fit my entertainment center and to save the $210 the 3x Dayton .50 cu foot enclosures would have cost.
    17,579
    Quote Originally Posted by carlspeak View Post
    Though I'd like to- it's a far journey, and my wife is due that month.
    Not gonna happen,
    new england
    964
    Quote Originally Posted by lucasa.miller View Post
    I like mine alot. The finish is smooth and shiny but not real cherry. There is a brace about 1/2 way front to back. It can be seen in the photos I provided. There was a minor issue with one of the grilles not adhering to the BB reliably due to the BB screws were a bit deep into the BB and the magnets on the grille frame couldn't be as effective. I just installed some small washers under the screw heads to make them flush with the BB face and now all is well.
    I can vouch for the cabinet's strength. One of the assembled cabinets fell about 3 feet onto a carpeted floor and there was not damage. Close call though!
    Austin, TX
    10
    Nice project! But is that a ferrous screw in the center of the woofer air core inductor? If so it will alter the inductance and likely add non-linearity.
    new england
    964
    Quote Originally Posted by sdl2112 View Post
    That was changed to a brass one when the whole coil came loose from its moorings.
    Jan 2008
    Oak Creek, WI
    143
    [QUOTE=carlspeak;1820319]If you're getting a good tax refund this year and are in search of a high quality 'build' mini-monitor project, read on....
    QUOTE]
    I too built a project in a PE 0.5 cu ft speaker cabinet. I used an RS180 woofer with a Seas 27TDFC tweeter. I can't take credit for the design though. Jay Kim designed the project including the crossover.
    I love the sound. Jay did an incredible job of voicing the speaker. My only complaint is the bass isn't quite deep enough for my liking. The bass rolls off rapidly below 50hz. To compensate I boost the bass at 30hz about 6dB.
    Your project uses really excellent (and expensive) drivers. I wonder how much improved the bass is on your project? You've got me thinking to perhaps putting your design into my 0.5 cu ft box!
ID:	21880   Click image for larger version.
ID:	21881   Click image for larger version.
    Jazz Wine HiFi
    new england
    964
    [quote=jimofoakcreek;1820592]
    QUOTE]
    A very handsome project indeed! I presume WAF or SOAF is high as well?
    I added another response test to the photobucket link which I should have put there originally. It shows the full extension of the bottom end with nearfield mic and vent mesurements. The woofer starts rolling off at 70 hz, and is 5 dB down at 60 hz, but the vent picks up only about 7 dB down and doesn't roll off until 30 hz. Those SS bass/mids are known for their awesome bass.
    The complex schematic you showed is what I avoided. To me, a simple 1st order elect. xo with great drivers is extremely musical. Some will criticize it, but no xo is perfect. They're all compromises.
    Jan 2008
    Oak Creek, WI
    143
    [QUOTE=carlspeak;1820608]
    Quote Originally Posted by jimofoakcreek View Post
    Yep, the wife is unreasonably sensitive when it comes to clutter in the great room. But she's OK with the .5cf curved cabinets on the stands.
    But I fear anything bigger would be testing her.
    She doesn't like SW's either.
    Jazz Wine HiFi
    Jan 2008
    Oak Creek, WI
    143
    The aluminum RS180 woofers have a twin peak resonance around 7-8K IIRC. That needs to be adressed in the XO thereby making it a bit more complex. They are crossed over quite low, around 1.6K.
    But I agree the simpler the XO the better when possible.
    Since I am ham strung with a .5CF box there is no sense in "up-grading" unless I know for sure I can get deeper bass than what I have now.
    Jazz Wine HiFi
    new england
    964
    Your tweeter circuit looks like it was no picnic either.
    Regarding the bass response, I suspect my relatively little bass/mid < 6" dia. is doing about the same as your 7 inch eq'd like you have it. It's plenty for me. As they say: YMMV.
