Results 1 to 8 of 8
Thread: SLS vs HDS
Hybrid View
    Mar 2011
    South Dakota, USA
    1,288
    Default SLS vs HDS
    Does any one know how this SLS compares to the 8" Nomex HDS, as far as distortion and flat response? Or any thing else that I should know?
    http://www.madisoundspeakerstore.com...r-cone-woofer/
    http://www.parts-express.com/pe/show...umber=264-1098
    Thanks.
    Oct 2011
    Tulsa, OK
    2,228
    Default Re: SLS vs HDS
    The SLS is a good speaker, but the HDS Nomex is an outstanding speaker. The HDS has lower distortion, flatter FR and is easier to build a cross-over for. There isn't that much difference in price, either. We need for the "smart guys" to work up a design, but the new Dayton Designer Series 8" woofer could be a less expensive option, as a 3-way. The Peerless HDS Nomex paired with a Dayton RS28F-4 and the right cross-over could be built as a WT I think. As LouC says "I never met a Peerless Nomex I didn't like." I have a pair of Dayton Classic 6 1/2"s and got a pair of Peerless HDS 6 1/2 Nomex's. I put both in my test box, and the difference is mind-blowing. I'll warn you, if you start buying "premium" drivers, your ears may make your wallet suffer!
    Mar 2011
    South Dakota, USA
    1,288
    Delete
    Nov 2005
    Prescott, AZ
    1,666
    Blog Entries
    2
    I bought some 8" SLS's here at PE and sent them back. T/S were not remotely as advertised. Might be good for some purpose, but not the same one implied by the factory specs. Could have been faulty.
    Sure wish PE would run a few of each batch through WT3 and see what they are selling.
    Feb 2009
    Tampa, FL
    894
    I did a build with some 830883's a while back. Online I found 2 different sets of maufacturers data which were not close to each other and another set of independently tested data that was different again (Zaph's?). I wonder if the manufacturing process has changes over the years.
    Jan 2010
    North
    851
    The HDS changed a bit when Tymphany took over. I've seen both, the cone material is slightly different, and the voice coil former is a bit longer on the Tymphany version.
    As has been stated, the SDS is a fine driver, the HDS is an excellent driver. That should be fairly obvious though.
    "Why does your amplifier hum?"
    "It hums because it doesn't know the words."
  7. #7
    Mar 2011
    South Dakota, USA
    1,288
    SLS, not SDS.
    Quote Originally Posted by dcibel View Post
  8. #8
    Jan 2010
    North
    851
    My typo.
