Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Hybrid View
    Mar 2011
    South Dakota, USA
    1,284
    Default WinISD or Madisound problem
    WinISD Beta and Alpha do the same thing.
    What's the deal, why is my F3 @ 70Hz, when the site says a 1.5 ft3 box will get me 47Hz F3?
    Thanks.
    Oct 2011
    Tulsa, OK
    2,150
    Default Re: WinISD or Madisound problem
    I think Madisound transposed 47 Hz for 74 Hz. That's the only thing that makes sense and what I got with WinISD (the newest version). I ran it three times, Beta, Alpha, and ISD to be certain. In 1.75 cu.ft ported I got a flat response (+.3dB). It would take a much larger sealed enclosure to be "ideal" by WinAlpha or ISD.
    Mar 2011
    South Dakota, USA
    1,284
    In that case, the Nomex does 19Hz better.
    Thanks.
    Nov 2010
    Erie, PA
    228
    icor fs looks to be 42Hz, it's right under Le on the spec page.
    Jeff
    Jun 2009
    Minneapolis
    2,110
    use something other than winISD and see what happens.
    I am trolling you.
    Feb 2012
    Putnam county, NY
    361
    Is there a solid version of WinISD ? I get a littler unsettled when I hear the words alpha and beta. I use the beta all the time, I have never used the alpha.
  7. #7
    Jun 2008
    PacNW, USA
    1,052
    As peepaj stated, the modeled FS is wrong. Change your 64 to 42.
    I use Unibox myself, and love it.
    - John
    "Injustice anywhere is a threat to justice everywhere." - Dr. M. L. King
    www.BuildTheDream.org
  8. #8
    Sep 2005
    Appleton
    5,867
    Quote Originally Posted by AR3A View Post
    "beta" gives results VERY SIMILAR to "Alpha" (a.k.a. "Pro") and to every other reputable box modeler out there.
    Beta has a couple features Pro doesn't have. And Pro can be a bit finicky with data entry until you get the hang of it. But Pro takes you ten times deeper into your explorations than beta can.
    You'll finally understand what's meant by "excursion limited".
    You can model passive radiators.
    You can dial in different amounts of "leakage" for your box.
    You can simulate a plate amp's low pass filter on a sub.
    And much, much more.
    Chris
  9. #9
    Mar 2010
    North Texas, USA
    3,122
    Do you have Excel?
    http://audio.claub.net/software/jbabgy/WBCD.html
    or
    http://audio.claub.net/software/kougaard/ubmodel.html
  10. #10
    Things to consider:
    WinISD Alpha Pro works fine, and is a reasonably accurate simulator provided you know it's qwerks and how to work around them. The most important thing is getting the driver data correctly entered. I like to let WinISD calculate most of the T/S specs from mechanical specs when entering driver information. There is an order that works well and prevents "problems." If you let WinISD do the calculations for you, and you see a discrepancy in it's results that are greater than say +/-10% from published specs, then you know there may be a misprint. At that point, it's a matter of experience deciding where the error most likely is, and either trusting your gut, or moving on to a different driver that doesn't have discrepancies.
    I don't recommend the beta version because without the ability to simulate Xmax vs Pe, amateur builders are apt to be lead astray simply looking for the most extreme "flat extension" without being shown the sacrifices in dynamic range that are given to achieve those response curves. Flat to 20hz doesn't do you any good if the system is Xmax limited to 90dB and you wanted a 110dB capable pair of speakers. Simulation looking for "deep flat extension" only will often lead to the use of high distortion drivers.
    If you want more accurate simulations, use Hornresp. Hornresp uses much more "industrial strength" math far beyond my comprehension, to produce a simulation result.
    Regards,
    Eric
  11. #11
    Mar 2011
    South Dakota, USA
    1,284
    Oh, I used F instead of Fs.
    Thanks.
  12. #12
    Oct 2011
    Tulsa, OK
    2,150
    Duh'o! I just plugged your numbers in 3 times and ran them...a Homer Simpson moment!
  13. #13
    Feb 2012
    Putnam county, NY
    361
    WinISD pro keeps telling me that there is a consistency check fail on Qts, Qms, Qes.
    For this driver
    http://www.parts-express.com/pe/psho...4-1078&scqty=2
  14. #14
    Feb 2012
    Putnam county, NY
    361
    I got it, don't enter Qts the program uses the other two to calculate Qts.
  15. #15
    Nov 2010
    Erie, PA
    228
    Check out this thread, post 13 has zaph's measurements. You could try using them.
    http://techtalk.parts-express.com/sh...d.php?t=230802
    Jeff
  16. #16
    Feb 2012
    Putnam county, NY
    361
    Thank you surprisingly WinISD calculated very close to his measurements
  17. #17
    For this driver
    I recommend a specific order of entering specs to prevent this problem with WinISD..
    Qms, Mms, Cms, Re, BL, Sd, Xmax, Pe
    If you follow that order, all other specifications will be calculated for you without any consistency problems. If one of these specs is not published/available, then come as close as possible to this order, then add 1 additional T/S spec at a time until the remaining important fields have been calculated.
    Regards,
    Eric
  18. #18
    Sep 2005
    Appleton
    5,867
    Quote Originally Posted by mdocod View Post
    Regards,
    Eric
    It's not really all that complicated. (With "auto-calculate" - or whatever it's called turned on) just enter the parms in the order that they "tab", L>R, top to bottom, but don't enter too many.
    I probably just enter Qes, Qms, (SKIP Qts - but watch it calculate it) Fs, Vas, Re, D (cone diameter - or alternately Sd, cone area), Le, Pe, and Xmax.
    Away you go.
  19. #19
    Hi Chris,
    How can you say "it's not really all that complicated" and then proceed to give a list of inputs that is equal in length to those I have provided? The complication is equal.
    The mechanical characteristics are less apt to have been "fudged" in the spec sheet. Following the suggested input order I have presented will result in greater precision in most cases. Also, you should skip entering Le, WinISD doesn't calculate for that correctly anyways.
    Regards,
    Eric
  20. #20
    My tutorial. Sometime this century I will upload the other parts...
    http://www.youtube.com/watch?v=j9jROjFPAis
    Why you should never support dog shows or breeders
    http://www.facebook.com/GcfCustomAudio
    Facebook
    My Website, a work in progress.
    "When a true genius appears in this world, you may know him by this sign, that the dunces are all in confederacy against him." -Jonathan Swift
    "Sure, the placebo effect is real - but there ain't no sugar pill gonna cure cancer."
    *Gort
