Re: how to proceed
For most things solid state, it should be fine. The phase is well behaved. Though looks like it hovers around 3 ohms quite a bit. May want to try the 8...
Re: how to proceed
How much are you padding the mid? Are you using a resistor in series, and one in parallel? Maybe you can delete or increase the one in parallel, and increase the size of the one in series by about 4 ohms.
Re: how to proceed
it took so much to pad them both, that i had to pad the woofer as well. this weekend, i'll try wiring the woofers in series and remeasure. buying the 8ohm version is an option though.
"Listening to music is perhaps the greatest and most profound source of happiness i have ever known. As soon as that music starts, every dollar becomes well spent, time becomes precious and there is no place i would rather be." Henry Rollins stereophile. august 2011
Re: how to proceed
You really shouldn't attempt to attenuate the woofers... ever...
just my opinion though.
Re: how to proceed
i agree. hence the reason for my post. i am far from being an expert and thought there my be some circuit that might help here.
by the way, for the intention of exporting for crossover design, how much smoothing should/can be applied to the fr measuremints?
Re: how to proceed
I export 1/24th for modeling, they are still kind of smooth with gating. I show off in 1/6th octave
Other than maybe doing a 3.5 way or something, that may help I dunno. Steeper slopes, maybe?
Re: how to proceed
Hello arlis,
Post a schematic of the x-over components/values, and your individual driver responses and driver data if possible. Padding the woofer sounds to me like a band-aid to some other issue going on. 4ohm mids and tweeters can often be implemented to produce an effective "8ohm" style load after BSC...
Regards,
Eric
Re: how to proceed
There's no reason to pad the woofer. The mid is louder. The woofer probably needs a coil of about 4 mH or more, and a cap to ground. Maybe 30 uf or so. That should reduce it's midrange. A 4 ohm resistor in series with the mid will reduce its output some, but probably not enough. Maybe 6 ohms, with a 12 ohm to ground. Just guessing really.
Re: how to proceed
Impedance looks a LOT better, good job! How do they sound like that? I'd think that looking at the response they might sound distant or removed, with the big room gain at the bottom and the rising top end, but I dunno. Though regardless this is a major step forward. Also, it must be nice to use the 150 so low that you don't need to worry about its breakup modes much... I keep pushing that little punk higher and higher lately but its a challenge.
Re: how to proceed
Maybe smaller caps and bigger inductors on the M/T. Especially the tweeter
Re: how to proceed
I wouldn't worry too much about the 100-200 dip in impedance, I have that in my Bento design and my 4 ohm capable amp seems perfectly fine with that (meaning the drop just below 3 ohms). However that dip between the RS150 and RS28A is fugly.
What blows my mind is that you have a series resister on both and its still so low. I'd look to see if 4th order electrical will be better, since I'd wager that 33 uf cap and .12 mh coil (OH MY GOD MAN) on the RS28 is a killer.
Re: how to proceed
Egads. The Khanspire uses a pair of 8ohm RS150's wired in series and still needed padding...
That said, I think that the mid-tweet integration can be more benign on the impedance side and still get the breakup way out of range. Keep at it.
C
Re: how to proceed
Re: how to proceed
Right, I assume you are talking about on the mid, and that will handle some power. I was just thinking about that since I needed a 3 ohm padding resistor on the mid for my Wavefront. I decided on two 25W erse 6 ohm resistors in parallel, figure 50W of handling should work nicely.
Re: how to proceed
What woofer is this. Surprised you need that much padding.
- You may not post replies
- You may not edit your posts
Forum Rules
