Results 1 to 10 of 10
    Feb 2009
    Ms Gulf Coast
    404
    Default Speaker Placement on 24' Horizontal Truss
    Thought I'd ping y'all for this question.
    If you had 4 full range 2-way speakers (QSC K12's I believe) and wanted to mount them on a 24 foot long truss (above the stage), how would you arrange the speaker for the best overall coverage. This will be for a large school dance. The subwoofers will be on the floor, center stage.
    Some say evenly spread out, which would be 8' center to center per speaker. But wouldn't this pose some comb filtering problems?
    Others suggest, 2 per side, splayed and pointed downward.
    Still another suggestion is 1 on each end and 2 at the center, splayed.
    Dec 2010
    WV
    2,833
    Default Re: Speaker Placement on 24' Horizontal Truss
    The 3 dimensional specifics of the "large school dance" are missing and are part of the details necessary for setup. As well as the dispersion of the QSC cabs
    That also depends on what each channel is reproducing and the degree of pattern overlap. Bob McCarthy ( for one ) explains this in much better detail.
    The distance of separation wasn't mentioned, but are you implementing delay to compensate?
    Feb 2009
    Ms Gulf Coast
    404
    Setup will be in a typical school gymnasium. Truss will be erected at front edge of the stage and the subwoofers will be placed at the front of the stage. The intended focus of the sound will be onto the large dancefloor area imemdiately in front of the stage, and maybe a good 50' back.
    If I recall, the K12 speakers have a 75 degree conical dispersion pattern for the horn.
    Dec 2010
    WV
    2,833
    I've seen gyms with inset stages and the boxed in stage area created a lot of boom and low end mud.
    Is this for a band or recorded music?
    Nov 2006
    New Hampshire
    5,701
    2 per side, vertically arrayed, the upper cab upside down, placing the HF horns adjacent. But unless you have certified flying hardware and a certified person to install them and the requisite insurance don't even think about flying anything.
    Dec 2010
    WV
    2,833
    The aforementioned MTTM array is one that I have used provided the layout warranted it.
    Not sure what a typical gym is - seen a lot of variation.
  7. #7
    Jun 2008
    Illinois
    128
    Quote Originally Posted by billfitzmaurice View Post
    I'll just add to take what Bill said very seriously, for legal liability issues.
    If a cab falls & hurts someone, unless all hardware & operator cert's can be verified, you'll be working to have your wages go to someone else for the rest of your life.
    Business insurance is a prudent buy. Knowing how to perform high risk tasks and being certified to perform high risk tasks are two completely different things.
  8. #8
    Feb 2009
    Ms Gulf Coast
    404
    ^^Agreed. The good thing is that the QSC K speakers do have fly points on them, and you can purchase the required brackets and accessories to fly them.
    On the topic of insurance, I wonder if they would deny the claim if the performer who flew the speakers using the mfg's recommended procedures, but wasn't certified to fly them.
  9. #9
    Nov 2006
    New Hampshire
    5,701
    Quote Originally Posted by Randy L View Post
    If it's not stated in the policy find out from the underwriter.
  10. #10
    May 2008
    Indiana
    779
    Blog Entries
    3
    Are there four tripod stands available for the speakers? The preferred solution might actually have one speaker on a stand in all four corners of the room, with subwoofers (either 2 or 4) placed midway along the walls equidistant from the speaker locations. If you have enough cable, this is what I'd personally do in your situation. This will avoid having a 'loud end' of the room, and it will help mitigate the smearing effects of the reverberant room because everyone will be able to hear clear first-arrival audio from the nearest speaker.
    [Speaker] . . . . . . [DJ Booth]. . . . . . . [Speaker]
    [Sub]. . . . . . . . . .[dancers] . . . . . . . . . [Sub]
    [Speaker] . . . . . [wallflowers]. . . . . . [Speaker]
    This will also put the maximum output right in the middle of the room, mostly time-aligned, and will put the subwoofer power alley in the middle of the room as well. In this setup, the speakers are all on tripod stands, subs are on the floor, and the truss can be used for lighting or for hanging a promotional banner. Hanging speakers from truss may seem like something the 'big boys' do, but K12s are not 'big boy' gear so they'd probably look silly flying from truss, and the 'big boys' use tripod stands too, FWIW. Your goal is to look professional and clean, not like redneck engineering.
    Best Regards,
    Rory Buszka
    Taterworks Audio
    "The work of the individual still remains the spark which moves mankind ahead, even more than teamwork." - Igor I. Sikorsky
    If it works, but you don't know why it works, then you haven't done any engineering.
