Results 1 to 18 of 18
    Feb 2011
    virginia
    29
    Default soldering to driver terminals
    Has anyone tried soldering wires from the crossover to the terminals on the drivers? If so:
    A: Could you hear any difference?
    B: Have you melted any voice coil wires?
    Dec 2010
    WV
    2,833
    Default Re: soldering to driver terminals
    Yes I have
    No to A:
    No to B:
    Oct 2005
    Little Chute, WI
    1,246
    It's generally not recommended. It becomes a hassle to remove the drivers and the constant soldering and re-soldering can lead to cosmetic damage of the frame...or worse.
    Rarely use anything but spade connectors. Too easy to fry tinsel leads, melt the insulator board. On some tiny tweeters, I've soldered leads (with heatsinks and trepidation) just cause the mounts were so fragile.
    Sound wise, I doubt that I could hear any difference. But some claim they can hear a flea fart when they make changes...
    Lou's Speaker Site [speakers.lonesaguaro.com]
    "Different" is objective, "better" is subjective. Taste is not a provable fact.
    A good speaker is like the right woman, the more you hear, the more you like.
    Yes
    No
    No
    Once the design is pretty firmed up I solder. Connectors are more of a pain for me. I've had them get pulled / slip off after the speaker is screwed in.
    That I know I can hear
    Removing a driver scares me more than soldering the terminals.
    The best laid plans of mice
    and DIY-ers
    oft go awry,
    ... when exposed to room acoustics
    Dec 2010
    WV
    2,833
    Quote Originally Posted by LouC View Post
    Hopefully you are not relating a bad past experience.
    I can honestly say that I've never damaged a driver from soldering.
  7. #7
    I use 16 (18 on tweets) AWG to wire internally with so it's no big deal for me to unsolder/resolder. Not like I am doing this 20-30 times.
    That small of gauge (with a bit of practice if you haven't soldered before) you are on and off the leads quick as to not cause a problem.
    16AWG is good for 9 amps. So not a problem by a long shot.
  8. #8
    I soldered a tweeter to death once, it was NLA. Ever since, I use push terminals almost exclusively. Sometimes I have to slightly modify them, they are generally to loose or too tight. Either a slight prying open with a small, flat tip screwdriver or a slight pinch from a needle nose pliers.
    Sometimes you can slide heat shrink tubing over the connection, for a little added peace of mind.
    http://www.youtube.com/watch?v=j9jROjFPAis
    Why you should never support dog shows or breeders
    http://www.facebook.com/GcfCustomAudio
    Facebook
    My Website, a work in progress.
    "When a true genius appears in this world, you may know him by this sign, that the dunces are all in confederacy against him." -Jonathan Swift
    "Sure, the placebo effect is real - but there ain't no sugar pill gonna cure cancer."
    *Gort
  9. #9
    Dec 2009
    Rockford, IL
    1,948
    Quote Originally Posted by johnnyrichards View Post
    +1
    They generally are too loose and I have to give them a little squeeze with pliers.
    Craig
    "I drive WAY too fast to worry about cholesterol"
    Why I don't spray in first gear: http://s1138.photobucket.com/albums/...t=100_2585.mp4
  10. #10
    Sep 2005
    Dallas, TX
    2,750
    Quote Originally Posted by daveinva View Post
    I guess it boils down to how good you are with a solder gun. I have soldered to hundreds of drivers over the years and to be honest don't ever recall any real issue. Tweeter terminals are most sensitive and require you have an appropriate gun. Of course I have seen what someone with little experience with a solder iron can do so simply ask yourself "are you comfortable with a soldering gun next to your new driver"?
    Also I just tin the connector on the driver then tin the wire I am going to connect and lightly tack them. Works great and contrary to a few examples in this post, it is very simple and non-destructive to remove if you need to. Plus I can't imagine why you would remove the wires from a driver multiple times even if you are tweaking the crossover values there would be no need to solder and resolder the wires on the driver. So not sure why so many people find the need to connect and reconnect wires to their drivers.
    It won't create an audible difference between a well connected spade connector.
    Dave
    If you can read this, thank a teacher.
    If you are reading it in English thank a Veteran
  11. #11
    Dec 2011
    Deer Park
    684
    Another factor is the quality of the soldering iron and solder you use.
    I use a Metcal Smartheat rework station and 1%cored tin-lead solder. Less chance of overheating because you are in and out in under 2 seconds.
  12. #12
    May 2008
    wisconsin
    2,616
    I solder. A little wet rolled up piece of paper towel will act as a heat sink to protect tiny tweeter connections. Per dthomas, tin the wire and terminal, quickly touch the iron to complete. No mechanical twisting or putting wire through hole in terminal. The holes in speaker terminals are for locking the mechanical spade connectors.
  13. #13
    Dec 2010
    Loganville, GA
    259
    Either way requires experience and patience or you can cause damage. I have accidentally de-soldered tinsel leads and I have pulled terminal pads off the frame while trying to remove tight spades. It really boils down to doing what you are more comfortable/have more experience doing. I have improved my soldering skills (and equipment) a lot in the last decade, so I usually solder mine.
  14. #14
    I do both depending on the driver. On drivers with tabs big enough to get a good connection with a push on terminal, I go that route. If the tabs are too small and short to make a good reliable connection with a push on terminal, I solder the leads to the terminals. As others have said, melt a drop of solder onto the terminal and tin the wire. Hold the wire against the terminal and apply the iron to the wire until the solder melts. This should only take a couple seconds. Remove the iron while holding the wire very still until the solder cools. If you move the wire before the solder cools, you will most likely have a bad connection. 3 - 6 seconds should be adequate cooling time. I haven't noticed any difference in sound quality with either connection type. I have pulled terminals off poorly manufactured drivers while trying to pull off a tight fitting push on terminal before. It's only happened a couple times and due to the terminal being poorly attached to the insulator. I try to get a good grip on the the insulator and the terminal now when pulling these apart to help prevent that from happening.
  15. #15
    Jun 2006
    North Carolina
    1,679
    I've soldered many, but what I sometimes do is put the wire through the hole, and twist it snuggly around the tab. I only recently started using spade connectors, and I'm amazed at how poorly they seem to fit most times. Opening up one with a screw driver is just asking to stab myself with the tool. I tried removing one that originally was loose, and had been tightened with pliers, and I nearly ripped the thing apart pulling it off.
  16. #16
    Feb 2010
    1,638
    Blog Entries
    3
    I tend not to trust the spade connections to not fall off of my drivers. What I've been doing is soldiering wire to the speaker leads and then adding a spade connection about 6" t0 9" away from the driver. That way I can still disconnect the speaker if I need to plus I get a better male to female connector connection than I would if i was attaching them to the drivers.
    Take it easy
    Jay
    "I like Brewski's threads, they always end up being hybrid beer/speaker threads based on the name of his newest creation." - Greywarden
    Breakfast Stout - HiVi RT2 II/Aurasound NS6
    Imperial Russian Stout - Vifa DX25/Fountek FW146/(2) Fountek FW168s - Built by Fastbike
    Ruination 2.5 way - Vifa DX25/Fountek FW168
    Levitation TM
    - Vifa BC25SG15/Fountek FW168
  17. #17
    Mar 2012
    New Zealand
    68
    Damn but that would have to be one big flea
    Gotta Love Dat Sound...
  18. #18
    May 2012
    Bessemer City, NC
    1,228
    Quote Originally Posted by Brewski View Post
    Take it easy
    Jay
    +1
    I like that idea and may have to try it myself...
