HDMI Signal Difficulties
I have run into a wall and am out of ideas. Maybe you have an answer!
Here is my scenario: I am trying to install a multi-display announcement board in a church. I am running the video announcements from an AppleTV to (at present) 2 TVs. One TV is about 150ft from the source. Here is my set up: Apple TV (source) to 2 to 4 powered HDMI Splitter. One line out goes directly to a TV that is about 5 feet away. Line 2 runs through a Cat5 balun to the second TV. This TV does not receive the signal.
However, if I skip the splitter the signal carries the distance with no difficulty.
I have tried upgrading the splitter and the baluns to no avail. Can anybody provide some insight?
Re: HDMI Signal Difficulties
Offhand ( short of actually testing the signal strength ) I would speculate that there is insertion-loss incurred by the splitter.
In which case a booster or repeater might work.
What brand/model of HDMI splitter and baluns are you using? What kind of display? More than likely it is a handshaking issue between your devices causing the problem, not a signal strength problem.
Welcome to the horrid world of HDMI. As an installer, man, do I hate it. As a consumer...meh.
First off, are you using single or dual CAT5/6 extenders(baluns)? The 2 wire type are notorious for being flaky. The HDMI over a single CAT5/6 wire are much, much better. They utilize a technology called HDBaseT or sometimes 10BaseT. The founders and promoters of HDBaseT are trying to make it the HDMI replacement, I hope they succeed. A good single CAT5/6 HDMI extender will be about $3-400. Gefen and Atlona are a couple we have had success with. Good splitters are very costly.
Anyway, the previous mention of signal loss is probably correct and more likely than a hand shake issue, although it is also possible. Finding a guaranteed solution is a crap shoot. There is really no way of telling which combination of source/splitter/extender/cable distance/display will work. There are some better units out there, but a stable and reliable HDMI splitter/extender will cost several thousand dollars.
Are you outputting a 1080p signal from the Apple TV? You might have better luck with a 1080i or a 720p source. Or, if it's the original Apple TV, you can use the component video output and get a component splitter/extender. Component is much, much more stable than HDMI and you are most likely not going to have these issues with it.
thank you for your replies. My best guess is that the issue is handshake problems. Since it is a new apple tv, there is no option for for output besides hdmi. I think it may be much more cost effective to simply get a second apple tv and sync them.
