Results 1 to 7 of 7
    Jun 2006
    North Carolina
    1,680
    Default Big, Old School 3-ways
    For some reason I just have the urge to build some speakers with a 12" or 15" woofer. The thing is, I'd rather do it with cheap drivers if they perform well highpassed, and crossed to a mid at about 400 hz. PE has several 12s and 15s for $25 to $85 dollars or so. My primary goal would be impact rather than bass extension. These would be used in a small room that is my HT / music room. With the woofers highpassed at 80 hz, I suspect the excursion would never exceed 2 mm even at full volume. Do any of the cheap large drivers sound good used this way?
    Oct 2005
    16,605
    Blog Entries
    1
    Default Re: Big, Old School 3-ways
    The Peerless 830669 in a sealed enclosure would be about ideal for your application. It's just outside your $85 target, but for the extra $10, it would be worth it.
    Byzantium Project & Build Thread || MiniByzy Build Thread || 3 x Peerless 850439 HDS 3-way || 500W/ch PC for 2ch music.
    Schumakubin Plans
    DA175 x 4, RS28 2.5-way || Prisstina Plans DA175 x 4, RS52, ND20-6 || Schumakubin MKII 5 X DA175, RS28F, 3-way || L.O.K.I. Project WG 2.5way
    Fallback position || It's just the weather || The Sun controls climate? Well Duh!!! ||
    The Fraud Continues || Hoax
    Mar 2010
    North Texas, USA
    3,132
    At the lower end of the scale you might look at the DC300. They cross at ~1600 in my Econowave application,yet have some old school presence.
    At 450Hz or so you should be pretty happy.
    A quick WBCD model w/ 80Hz highpass, 400Hz low pass shows 108dB w/ 80 watts well below Xmax (i.e. ~2mm) everywhere. 2.2ft3 net sealed, QTC .76. F3/f10 78/51
    Jun 2006
    North Carolina
    1,680
    Quote Originally Posted by Pete Schumacher ® View Post
    I really want to use something under $50 each if the drivers perform well at typical HT levels. If I could get a very low Q driver, that would be ideal, but they tend to have large expensive magnets. The 4 ohm Realistic Mach One driver at $50 looks interesting. I don't suppose a big 15" 3-way has a very high WAF. That's not an issue for me though. The bigger issue is moving the beasts around on occasion.
    Jun 2006
    North Carolina
    1,680
    Quote Originally Posted by fastbike1 View Post
    An F3 of 78 hz would be ideal, and a box size of 2.2 cubes is back friendly as well. I'm hoping for an "audiophile" type of sound with music, but want a little more thump with action movies.
    Jan 2010
    Maine, Bangor area
    41
    Quote Originally Posted by rpb View Post
    How about MCM 55-1465? This is a 12" dual voice-coil driver that goes for less than $50. each.
    Fs = 25 Hz
    Qts = 0.3
    Vas = 204 liters
    Xmax = 5.0mm
    These are great imo, they can be driven very loud without distortion, that is in a sealed two-way system with internal volume equal to about 2.8 cubic feet yielding f3 = 39 Hz, & crossover freq. = 2 kHz.
    In fact I have a second pair on hand currently just sitting on the shelf, but you probably would want to get a pair from MCM (electronics).
  7. #7
    Jun 2006
    Atlanta, GA, USA, Earth
    1,955
    There is something to be said about those old school monkey coffins. We listened to these Fishers for many years and loved them. I recently reworked them prior to gifting them, and they measured very flat.
    My large number of posts is not because I'm an expert. Most posts are "I don't understand"
    "I think I hear a difference - wow, it's amazing!" Ethan Winer: audio myths
    "We're down to our last 5 pairs of speakers!" (paraphrased, Ms. Ken Lay)
    NS6-255/Vifa BC25SC06 TM design - AURBACS
    NS6-255/Vifa BC25SC06 MTM design - MAURBACS
    High value, high quality RS150/TB28-537SH bookshelf - TARGAS
