Results 1 to 11 of 11
    Mar 2008
    North Dakota
    1,433
    Default Blue Icicle question???
    I'm working on getting a setup working so I can do some speaker measurement; ARTA and/or HOLM. I've been getting a lot of help from some very knowledgeable TT members. Things aren't going very well and we're thinking there might be a hardware issue. I'm using a Blue Icicle, but in device manager (the BI is labeled USB Multi-Channel Audio Device), it says the USB device cannot start (Code 10). I know this is referring to my BI because when I unplug the BI, the USB Multi-Channel Audio Device entry goes away. I'm using Windows 7.
    Any suggestions how I can get the BI "started?"
    Mike
    Mike Jennens
    "We're speaker geeks, not speaker nerds. Nerds make money!" Marty H
    Bismarck, North Dakota
    My Current System: Marantz PM8003 amp, Squeezebox Touch, and Continuum TLs
    My Other Current System:Marantz 2238B and Nano-Neos
    Still Another System: Sony STR5800SD, MarkAudio CHP-70s in a Planet 10 Slim GR
    Jul 2010
    Yonkers, NY
    1,551
    Default Re: Blue Icicle question???
    Check windows support. There is a possible device driver issue.
    Mar 2008
    North Dakota
    1,433
    Quote Originally Posted by kenny_k View Post
    Thanks for the info. I just emailed them. Hopefully this will solve my problem.
    Mike
    Mike Jennens
    7,507
    I use mine with XP and there are no issues, plug it in and it loads the drivers, then in the HolmImpulse control panel it shows up as a USB Mic. You can tell it's working by turning on the Record Meter.
    I just remembered, I loaded my shop laptop with W7 a few months back and the Blue works the same on it as it did with XP.
    Mar 2008
    North Dakota
    1,433
    I happen to have an older laptop with XP on it. When I use it, it recognizes my BI. However, I get the following error when I click on the StratRec icon - "waveInOpen: The specified format is not supported or cannot be translated. Use the capabilities function to determine the supported formats." I have no idea what that is and I can't find anything I can use on a Google search. All I can say is GRRRRRR!
    Mike
    Mike Jennens
    7,507
    Quote Originally Posted by mikejennens View Post
    When I look at it in Device Manager it shows up as USB P n P (plug and play, I imagine) device. What is StratRec? ARTA? Can't help you there.
    Nov 2010
    Erie, PA
    360
    Jeff
    Sep 2010
    NW FL
    4,357
    Idk man, I just plug mine in and it works... There has never been an issue other than audio input/output swapping, which takes all of a few seconds to sort out...
    रेतुर्न तो थे स्रोत
    return to the source
    leviathan system thread
    deadhorse thread
    harbinger coming soon
    instagram :: greywarden_13
    in war, victory . . . in peace, vigilance . . . in death, sacrifice.
    Jul 2010
    Yonkers, NY
    1,551
    Try changing USB ports. One may act as the primary and may cure your problem.
    9,176
    I've got a fairly old (5yr+?, and CHEAP) Compaq tower running Vista Home, and just using the onboard sound (chip). It's got 2 USBs on the front panel. If I right-click on the little speaker icon (down on the "tray"?) and open up "Recording Devices", it says:
    MICROPHONE - Realtek HD Audio - Not plugged in
    LINE IN - Realtek HD Audio - Not plugged in
    As soon as I plug my Blue Icicle into EITHER port, I hear a tone ("ba-loop"), and immediately, added to the top of the list (with a green checkmark) I see:
    MICROPHONE - Blue Icicle - Working
    I've never had any issues with it.
    'Upstate' NY
    2,037
    Mike,
    I've got blue icicle working on a very old Compaq laptop and Windows 7. I suspect like peepaj that it is a corrupt Windows driver that comes with the operating system (not a downloadable driver). Are you using the laptop for anything else? If not, perhaps a re-install of the operating system and an update might be the way forward.
    John
