Results 1 to 20 of 24
    Vermont
    48
    Default midrange suggestions
    Hi Everyone,
    I'm seeking advice on what to use for a midrange driver in a 3-way setup. I'll be using a RS225 for the woofer and a Morel MDT10 (NLA) for the tweeter, because I already have them. I want a driver with low distortion and a smooth roll-off. I figure it should be able to be crossed around 300/3000. Budget is under $100.00 each.
    Tom
    Aug 2011
    Mayfield Heights, OH
    1,975
    Default Re: midrange suggestions
    Quote Originally Posted by Thomas Moore View Post
    ... I figure it should be able to be crossed around 300/3000. Budget is under $100.00 each.
    That leaves a heck of a lot of drivers. Are you thinking dome or cone?
    Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
    Sites: Jupiter Speakerworks - SpeakChat 2.0 - Flicker Stream - FRD Consortium Archive - Proud Member of Midwest Audio Club
    Vermont
    48
    I'm thinking cone. No metal. My current design is using the RS52 midrange. I'm not really happy with it.
    Aug 2011
    1,975
    Parts Express has the Vifa NE123W-08, which is from a great driver family, 4", advanced motor. Its 80$ though, so towards the top of your spending limit. At the same place the Peerless 830991 5-1/4" GFC Cone HDS Woofer would do the trick, I recommend it because what I am seeing in its 6.5" brother is rather impressive. Also a lot cheaper at 47$ On the bargain basement bottom is the Vifa TC9FD-18-08 which test really well, Zaph did it a while back and that is like 10$
    Madisound has the impressive Scanspeak Discovery 10F/8424G, while at 100$ is your top end but its one hell of a driver. You can just look at it and tell that, plus more measurements from Zaph. They also have a Seas MU10RB-SL (H1658-04) 4" Woven Poly Cone Midrange which was designed for Linkwitz's LX521, and that looks really solid. I could go on, but I think this is enough time and I covered a nice range of drivers
    Jan 2013
    Hampton Roads Virginia
    1,226
    http://www.madisoundspeakerstore.com...r-cone-woofer/
    This Seas paper cone 5.5" is on sale at Mad.
    There is this glass/fiber cone ScanSpeak for a little more money...
    http://www.madisoundspeakerstore.com...idrange-8-ohm/
    Or if you want to break the budget a little and try something you don't see often then this Eton might be nice.
    http://www.madisoundspeakerstore.com...uminum-former/
    Disclaimer; I have used none of these. Listening to someone with actual experience with what they recommend might be better, but I was just thinking out loud.
    Dec 2008
    Long Island
    4,264
    Default
    Another vote for the 10F 8ohm. Sounds great, low distortion, and very easy to work with.
    http://www.diy-ny.com/
    Vermont
    48
    The Eton looks great, if the chart is accurate. It's a little pricey, though. Still, I'm not ruling it out. The Scan Speak 10F looks good. How hard is it to tame the rising response?
    Aug 2011
    1,975
    Its possible that rise is an effect of their measurement conditions. See Zaph's measurement of the 4 ohm version below:
    There is still a slight rise, but its nothing like what they are showing. This test is on his large flat baffle, IIRC.
    Vermont
    48
    That looks very good. Do you know of any third party measurements of the 8 ohm version? Any distortion measurements?
    Aug 2011
    1,975
    Zaph did the 4, I think its reasonable to expect similar performance from the 8, you can find it here: http://www.zaphaudio.com/blog.html The page is large, just F3 or Ctrl+F or whatever and search 10F and you can find it down in the middle somewhere.
    Jan 2013
    1,226
    http://www.zaphaudio.com/5.5test/
    This is Zaph's test of 5.25" drivers. There may be something you like there...
    Jan 2010
    North
    2,057
    Scan Speak 10F or 15M/4624.
    If listening to music in stereo is wrong, then I don't want to be right!
    Dec 2008
    Long Island
    4,264
    Very easy.
    21,567
    *InDIYana 2016 event*
    Jan 2013
    1,226
    Wolf, the SB and Seas items look nice. I saw you mentioned the keronite Eton mid, but I didn't see the link for it. I have thought that unit might be really nice too. Link...
    http://www.madisoundspeakerstore.com...-matched-pair/
    21,567
    I thought it was linked above. Oh well...
    BTW- there are 3 versions of that Curv 4" that Linkwitz used; his, and an 8 ohm and 4 ohm version of the unused-by-linkwitz variety that may be cheaper.
    And you have to admit, there is something about Audax Aerogels....
    Vermont
    48
    Thanks everyone,
    Has anyone used either of the SB drivers that Wolf provided the link to? They look like a good value. They are very similar in price and specifications. I'm curious to know what the performance differences may be between the two. Why would you choose one over the other?
    Tom
    Jan 2013
    1,226
    I thought that was the case. I had linked to one of the new Eton Symphony hexacone units which doesn't look too bad either. But if that 3" keronite will have enough output for the project it looks like it could be good.
    I lusted after audax aerogels for a long time back when they were the new thing but never have heard any.
    Vermont
    48
    I think I'm going to use the Vifa NE123W-08. My question is, can this driver keep up with a pair of RS225-8? It seems as though by the time you subtract baffle step and add bandpass gain, it should do alright. Also, in order to use two RS225, I'll have to buy two more to go with the ones I purchased years ago. Have the specifications of the RS225-8 changed over the years? If so, enough to make a difference?
    Tom
    Feb 2012
    Oregon
    485
    Would the NE123W-08 be better than the SB drivers or just different?
