Page 1 of 5 123 ... LastLast
Results 1 to 20 of 91
    Nov 2012
    Iowa
    615
    Default Maximus "Build Thread"
    My goal for this build is some nice high end towers for my man cave. I am basing part of my design off of Elemental Designs EL8 series speakers. The goal is to have a full 7 speaker setup using all the same drivers.
    The drivers that I have chosen to complete this task is the:
    Peerless 830869 8" Nomex Cone HDS Woofer
    Tang Band 75-1558SE 3" Textile Dome Midrange
    Morel CAT 408 1-1/8" Compact Soft Dome Tweeter
    For the towers I will have two 8" Peerless, 3" TB Mid, and Morel tweeter.
    The drawing is a little different, but I plan on relocating the port to the rear of the box and the mid will be mounted on the backside of the baffle with a 45* chamfer.
    So far with this project I have received the drivers and done some frequency response testing and working with PCD to get the hang of things. Here is what I have come up with so far using SPL trace and ZMA files I got with DATS.
ID:	35930 Click image for larger version.
ID:	35932 Click image for larger version.
    The response is nice and flat and I also have the baffle step included in the woofer response file. After playing around with different settings in PCD and using a couple other software, I really tried to keep the crossover simple. If anyone spots a bad thing let me know, I will not be able to test the true FR of the drivers until I build the boxes.
    Give a little idea of the box, it will be about 75L with a 4" port tuned to 37 Hz.
    If anyone has suggestions/comments they are more then welcome.
    Default Re: Maximus "Build Thread"
    This has the potential to be a really good speaker when done right. Is this a purely simmed design? It does not look like you have put in the driver diameters and offsets. Did you also ran this into Response Modeler to account for baffle step/diffraction and was the minimum phase extracted for the drivers?
    21,567
    Ditto, Morris.
    *InDIYana 2016 event*
    Nov 2012
    Iowa
    615
    Here is an update image with all the diameters, listening distance, height, driver location, and minimum phase.
    None of the component values were changed and it still comes out pretty solid. The FR is simulated with using SPL trace, response modeler, and the ZMA file is the real driver. The FR file also has minimum phase, box response, and baffle step included.
    Does my crossover look good or do I need to do some improvements?
    Nov 2010
    Erie, PA
    360
    Tom, your driver locations should be -.127 and -.0635 the way you have it the woofers and mid is above the tweeter. Also you don't have a z offset this will have an effect on your crossover.
    Jeff
    Laporte, IN
    4,516
    what's up with the series resistor on the woofers?
    Sep 2010
    NW FL
    4,357
    Already looks to me like you need a bigger coil on the woofer that bump there will likely turn into an audible wart. Also when you have the z offsets in, you should pan up to 45 degrees off axis and see if you need to lower or possibly raise your crossover points.
    रेतुर्न तो थे स्रोत
    return to the source
    leviathan system thread
    deadhorse thread
    harbinger coming soon
    instagram :: greywarden_13
    in war, victory . . . in peace, vigilance . . . in death, sacrifice.
    Nov 2012
    Iowa
    615
    Quote Originally Posted by peepaj View Post
    When figuring the driver location, is it based off of a corner(top left, right, bottom) or is it based off of the tweeter?
    How would I figure the Z offset?
    Quote Originally Posted by isaeagle4031 View Post
    I used the resistor to raise the impedance so it would not drop as low but I could just remove it.
    Dec 2009
    Rockford, IL
    3,679
    Driver offsets are referenced off the tweeter.
    Craig
    "I used ta do a little but the little wouldn't do
    So the little got more and more"
    Sep 2010
    NW FL
    4,357
    A resistor in series with the woofer is asking for a fire. I'll refer you to the "hot crossover" thread lol
    रेतुर्न तो थे स्रोत
    deadhorse thread
    21,567
    read...
    http://techtalk.parts-express.com/en...-and-some-tips
    http://techtalk.parts-express.com/en...me-2-The-setup!!
    http://techtalk.parts-express.com/en...-Volume-3-quot
    We also cannot see your individual driver phases, power response, or your electrical phase. These are important factors.
    Thanks for postings these Wolf! I've been wondering how to properly model a tank in PCD. Sweet!
    read...
    Nov 2012
    Iowa
    615
    I have a lot of work ahead of me. I adjusted the driver locations(x, y, z) and wow, went from good to complete cr@p on response and phase.
    Thanks for the links Wolf, read through them, and now have a lot to digest.
    I hope to build the enclosures sometime soon so I can get all my measurements from OmniMic, but for now the plan is to keep working with PCD.
    21,567
    Quote Originally Posted by Thumper Tom View Post
    Something told me if you had all the criteria entered that it would no longer be as pretty. That is one indication on someone doing a 'very-first-sim' for flat response- if it looks too pretty, it very well may be inaccurate.
    They are linked in the Speaker bible in the sticky thread, so maybe you just did not see them. Glad it was of help.
    Just remember you can fenagle PCD to do what you want by using 99999 for infinite connection, 99999 for every large cap if you can't remove it from the picture and just want a shorted cap position, etc. You can make it do things more than just a plain schematic. With careful usage, PCD is more versatile than you may think!
    Nov 2012
    Iowa
    615
    Wolf, would my listening height be set to 0 if my focal point is ear level, then adjust the angle to see what off axis response would be?
    Nov 2012
    Iowa
    615
    Here we go, adjusted the listening height to zero and input nominal values for the components along with proper DCR values.
    The two images are one with total phase and another with driver phase.
ID:	35949 Click image for larger version.
    Dec 2005
    Bloomington, IN
    2,393
    Pushing your woofer to mid XO lower should improve your power response.
    Dan N.
    Sep 2009
    Mumbai, India
    250
    And I think your z-offset numbers for the woofer and mid drivers should be -ve values.
    Quote Originally Posted by keith_correa View Post
    Made that mistake before!
    Nov 2012
    Iowa
    615
    Quote Originally Posted by Limelight View Post
    Reading the tutorial in the help section of PCD it suggests that version 6 the values are negative and version 7 they are positive.
    If we all reacted the same way, we'd be predictable, and there's always more than one way to view a situation.
    What's true for the group is also true for the individual. It's simple: Overspecialize, and you breed in weakness.
    It's slow death.
    //Burn n' Die//Dream Weaver//Maximus//ABC Bookshelf Speakers//Dayton Twin Towers
