Page 1 of 18 12311 ... LastLast
Results 1 to 20 of 341
    18,778
    Default Home/Pro 8" 2-way: RS28A and B&C 8BG51
    This thread is to document a build using the RS28A in a waveguide teamed up with the B&C 8BG51 Neo motor pro-sound mid-woofer.
    Tom Jones (takitaj) provided the baffle. He fashioned a waveguide to fit the opening of the RS28, 2" deep, 7" overall width, with a smooth curve that ends tangential to the baffle. I'm unsure yet as to how well it will work but I have high hopes. It follows fairly closely the profile of the larger guide made by DanP with a 3D printer a couple years back. That guide was wider, with a larger radius profile. This one features the same throat opening, and same depth. Exit angle is a bit smaller at about 90 degrees.
    Tom's baffle is made to replace the baffle on the .75 cf TM Parts Express cabinet, using the same mounting screws, so it will be removable to allow mounting the tweeter onto the rear of the baffle.
    I expect the baffle to be here tomorrow so hopefully I can get things mounted and start testing. I want to bring this to the KYDIY this weekend, so I probably won't have time to get any paint on the baffle. Hopefully, I'll have enough time to get a crossover built along with getting some voicing time in.
    This will be an 8 Ohm system, and I'm guessing at around 87dB overall sensitivity after baffle step, with F3 about 47Hz, and should be able to produce over 110dB from 50Hz on up. Not too shabby for a stand mount monitor. I'm going to try a 2.5" port which will have 38m/s port velocity with 100W input. It's a compromise for sure, but the smaller port pushes the port resonance up above 1KHz. And for normal listening levels, port velocity will be low enough to not cause problems.
    More to come as progress continues.
Name:	woofer bass alignment.gif
    Last edited by Pete Schumacher «; 12-14-2013 at 04:51 AM. Reason: corrected exit angle
    Jan 2013
    Hampton Roads Virginia
    1,226
    Default Re: Home/Pro 8" 2-way: RS28A and B&C 8BG51
    Looks like a very cool project Pete. Can't wait to see how it turns out.
    Quote Originally Posted by Pete Schumacher « View Post
    Tom Jones (takitaj) provided the baffle. He fashioned a waveguide to fit the opening of the RS28, 2" deep, 7" overall width, with a smooth curve that ends tangential to the baffle. I'm unsure yet as to how well it will work but I have high hopes. It follows fairly closely the profile of the larger guide made by DanP with a 3D printer a couple years back. That guide was wider, with a larger radius profile. This one features the same throat opening, exit angle (120 degrees) and same depth.
    18,778
    Ran a sweep of the 8BG51 nearfield, mic about 3" from the dust cap, just outside the front of the woofer flange. I'm guessing about 1W input. Ungated, no smoothing. This looks close to the manufacturer's data. Clean performance up to 1K. I hope the RS28A/guide can meet up with this without too much trouble.
Name:	8BG51 nearfield 1W no baffle nearfield.png
    So what's the major "diameter" on that woofer?
    Aaron
    18,778
    Quote Originally Posted by aarond View Post
    From the PE product page:
    Overall Outside Diameter 8.8"
    Baffle Cutout Diameter 7.4"
    Depth 3.50"
    Bolt Circle Diameter 8.3"
    Ha, I looked there but didn't scroll down to see it. I'm still not used to the (not so) new site format. I didn't see an "A" dimension in the description and assumed they left it out because of the odd shape.
    So practically speaking it's the same OD as the RS225, which is what I was really wanting to know.
    Following along, enjoying the ride.
    Aaron
    8,074
    cool Pete. Eager to see how the WG works out.
    Nov 2007
    Lil' Rhody
    4,061
    Pete, looks really interesting. I have been eyeballing that 8" BC for a while.
    18,778
    Well, getting this to KYDIY is going to be tough. The baffles need to be modified on the back side in order to fit into the cabinets. It'll take some creative router or table saw work but the mod shouldn't be more than time consuming.
    In the meanwhile, I got the RS28A mounted and ran a sweep. I'm liking the looks of this guide. Should be a perfect match for the cutoff knee of the woofer.
Name:	RS28A in guide.png
    18,778
    Well I couldn't get the baffle all the way onto the enclosure, but it did fit well enough to get a measurement of both woofer and tweeter together without the dipole cancellation on the woofer. I really wanted to start on a crossover design.
    So far,so good. 8 components yields this system response. LR4 at 1200Hz.
Name:	System response.jpg
    Pete, is this wg the same as the LOKI or is it slightly smaller? Speaking about the LOKI, is that design dead? I hope not!
    "It is only Scrooge McDuck and others with a personality disorder who have money as their goal"
    Jan 2013
    1,226
    That should be an excellent HT speaker for folks that want high output levels from a standmount form factor. I'm sure it will ne nice for music too, but reasonable sensitivity and extension in a standmount box with pretty high output levels is a nice combination.
    18,778
    Quote Originally Posted by jonasz View Post
    L.O.K.I. will resume when the new reference drivers come out. The 8" composite cone should be around in February (or there about) according to Rory.
    This particular guide is slightly smaller than the original and from the looks of it, doesn't extend quite as deep before cut off. Otherwise, it still produces the same smooth transfer function.
    Aug 2011
    Mayfield Heights, OH
    1,975
    Distortion looks excellent all the way down to 1 khz, and that is impressive. Most of the response slope is nice and smooth, great work. I'm not sure I like that massive early roll-off though. I wonder how audible that will be in the end.
    Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
    Sites: Jupiter Speakerworks - SpeakChat 2.0 - Flicker Stream - FRD Consortium Archive - Proud Member of Midwest Audio Club
    18,778
    Quote Originally Posted by JasonP View Post
    Good point. I'm not sure how much of it is really there. These were all far less than optimal measurement conditions. Once I get the baffle into the cabinet properly, I'll get a new set of data.
    But it looks like this will not make it to KYDIY. Just not enough time. And now, my traveling partner has come down with a bad chest cold, so I'll likely be staying home to baby sit her.
    Grenada, West Indies
    1,754
    Hmm... that 2dB rise @ 4kHz might stand out a bit on certain passages...
    Mar 2011
    Chicago - the guts
    5,081
    Pete I have a dumb question regarding your PCD screen shot. Why is there such a large SPL disparity between the individual raw driver responses and overall system response? What happened to the sensitivity? FWIW, this is why I am attending Jeff's PCD speaker design seminar...LOL. So what's going on there?
    18,778
    Could be. The RS28A has a bit of a rise at that frequency which is built into the tweeter. Only harmonics should be emphasized, and only a little bit at that. The top octave roll off seems to be another feature of the RS28A which according to manufacturers measurements as well as third party, definitely drops off quite a bit above 14KHz. That's a "feature" of 28mm hard domes that stay pistonic over their operating range.
    I'll post a series of off axis plots once the baffle is mounted to the cabinet. When you start getting off axis, the high end response actually improves.
    18,778
    Holm impulse only displays data relative to 0dB (full range). So when exporting FRDs for use in PCD, I first add 99dB and then export. That way, they show up in Jeff's default display range.
    These PCD plots are not relative to 1W, thats for sure. The raw response plots were taken with at least 1W to the drivers.
    Mar 2011
    Chicago - the guts
    5,081
    OK, I can understand the part about Holm and the response not being SPL accurate, but I guess I was wondering more about the 15db drop in sensitivity at 1.5k. At the end of the day, the raw response IS relative to the final system response, yes? So you're still expecting the final iteration of this to be about 87db? Really showing my noobishness right now…..
