Results 1 to 19 of 19
    Default DTA-100a question
    How is this little amp at handling not so efficient speakers, lets say 87db ?
    Apr 2013
    Nashville, TN
    230
    Default Re: DTA-100a question
    You'll get maybe, about 15 watts per channel out of it. so it should do just fine for normal listening levels.
    21,575
    Quote Originally Posted by pknaz View Post
    It is a 200W supply. I wager some more than that.
    *InDIYana 2016 event*
    9,212
    If it can generate 10w into your driver load (which is what?), then you'd be at 97dB. If 50w, then 104.
    Apr 2013
    Nashville, TN
    230
    Assuming this is the amp you're talking about?
    https://www.parts-express.com/dayton...0-wpc--300-383
    21,575
    Unless he mistyped, yes.
    Mar 2010
    North Texas, USA
    3,915
    it's an honest 30w/chan @ ,1% thd. It can drive OS MTM loud enough to be heard over a router w/ muffs on. Guessing is no substitute for experience.
    Apr 2013
    Nashville, TN
    230
    For some reason I had it in my mind that I saw a thread a while back saying that these were only capable of putting out 10-15 watts per channel with the supplied 2amp PSU? I could be imagining things, it wouldn't be the first time!
    Mar 2011
    Chicago - the guts
    5,081
    You're thinking about the TA2020s, like the little Lepai. The DTA100 is not in that camp.
    Apr 2013
    Nashville, TN
    230
    See, I told you I was imagining things! - thanks for clearing that up.
    Oct 2011
    Tulsa, OK
    3,905
    I have the DTA-100 and it loads a clean 110 volts each channel driven with a 1000 Hz sine wave into my big 8 ohm non-inductive resistor before the resistor starts heating up (about 30 seconds). That's about 37 watts per channel, and I think the power supply holds it back a little. When I was in high skool and lusted for an EICO 30 WPC amp kit that was $150 smackers ( or half as much as I paid for my used '58 Imperial), The DTA would have sent me to the moon. Oh yeah, the technology that's in it didn't exist we we went to the Moon...
    Mar 2011
    Chicago - the guts
    5,081
    I have the DTA-100 and it loads a clean 110 volts each channel driven with a 1000 Hz sine wave into my big 8 ohm non-inductive resistor before the resistor starts heating up (about 30 seconds). That's about 37 watts per channel....
    Um, you sure about that?
    May 2012
    chillicothe, ohio
    2,884
    I am sure that I am not sure about it. listened to and been around that amp a lot. I think I will have to go with pknaz, if you can get 18 to 20 watts I think you would have it maxed. I do not think I would want to do that for long.
    craigk
    " Voicing is often the term used for band aids to cover for initial design/planning errors " - Pallas
    Mar 2011
    Chicago - the guts
    5,081
    I was questioning the VOLTS.
    21,575
    Yeah- me too. I don't think a 24V/5A PSU will send 110VAC through the outs of an amplifier.
    Not happening,
    Oct 2011
    Tulsa, OK
    3,905
    Sorry my albuterol pumped brain couldn't do math last night. Never try and look at notes on the laptop and type on the desktop. I don't have 'em "synced" yet. The XP/Win7 file transfer conversion isn't stupid easy, and I'm plenty stupid.
    Mar 2011
    Chicago - the guts
    5,081
    It's simple math, bro. Kinda silly to even suggest that high voltage is involved with little t-amps. Next thing you know we're going to be seeing youtube videos of people blowing up houses with Lepai TA2020s or "death by TA2020" or something equally as insane. Perhaps the "knockout game ft. the TA2020"...... Maybe retail sales of Tripath amps will go straigth into the toilet as shell shocked consumers avoid the "lil amp that kills."
    Oct 2011
    Tulsa, OK
    3,905
    The DAT-100a isn't THAT little. It is rated at 30 watts RMS per channel @ less than .01% THD @ 8 ohms. I thought I understood from a previous thread the Tripath TK2050 chipset in this amp could handle a Vmax of 32 VDC across the rails, but the OEM capacitors were rated at 30 WVDC, so the 24 VDC stock power supply was about as high as you should go. I could remember it wrong. 24 volt in @ 2.5A=60 watts input (per channel). Assume 50% efficiency=30 watts output @8 ohm (2.83 Volts)=> 84.9 Volts RMS per channel in theory anyway. I quit at about 60 volts per channel, so 21-ish watts per channel, 120 volts total, if I can read my "notes".
    21,575
    E = I*R
    P = E*I
    Therefore....
    P = I^2*R or E^2/R
    24*5 = 120W
    60*8 = E^0.5, so Voltage is 21VAC for each channel peak.
