Results 1 to 20 of 24
    Jul 2006
    Davis, CA
    2,221
    Default ALERT: good spdif input 24/96 DAC for only $40 (with measurements)
    I have been exploring the realm of the "low cost DAC". This is the second DAC that I am reporting on.
    Now here we have a real contender - the "Little Bear Decoder v1.08". This is a 48kHz/96kHz spdif input DAC using a DIR9001 spdif receiver IC and the CS4398 D-to-A chip. The output is run through a 5532 op amp to provide low pass filtering and to buffer the output. The quality of the board seems to be high and good quality parts are used in critical areas.
    I performed some measurements on this DAC using an M-Audio ProFire610, ARTA/STEPS and REW. For these measurements, the signal path begins in software, goes to the 610 spdif output port, into the DAC, and then back into an analog input port of the 610. Software can then evaluate the analog input (for distortion, frequency response, etc.). This signal path also permits me to do A/B testing (after level matching) of the 610's internal DAC and the external DAC using the 610's routing software.
    I have attached the measurements I obtained. At both 48kHz and 96kHz the distortion levels are low and more or less input-level independent. I also took a spectrum of the DAC output for a 1kHz test tone, showing distortion products and the noise floor, both of which are very low. Keep in mind that the distortion spec for the analog input of the M-Audio Profile 610 that I am using to measure this DAC is 0.002% distortion (at 1kHz -1dBFS) and -108dB S/N ratio (A-weighted). Essentially the "Little Bear" DAC is approaching the measurement threshold of my equipment.
    This is an exceptional product, especially given that I purchased it for $40 including shipping to the USA. Power is supplied via a single 12-0-12 VAC input, and a transformer is included by the seller (115VAC or 230VAC primaries are available). Once you connect the transformer the unit is ready to run.
    If you are looking for an SPDIF input (only) DAC then this is really one that performs far above its price level.
    Ebay link:
    HiFi Digital to Analog Coaxial Decoder DIR9001 CS4398 96kHz 24bit DAC Converter | eBay (or search under "Decoder DIR9001 CS4398")
    Aliexpress link:
    Little Bear DAC on Aliexpress.com
Name:	Little Bear DAC v1.08 distortion at 0dB 48kHz SR.png
Name:	Little Bear DAC v1.08 distortion at 0dB 96kHz SR.png
Name:	Little Bear DAC v1.08 distortion at -20dB 48kHz SR.png
Name:	Little Bear DAC v1.08 distortion at -20dB 96kHz SR.png
    Jul 2006
    Davis, CA
    2,221
    Default Re: ALERT: good spdif input 24/96 DAC for only $40 (with measurements)
    Frequency response plots and spectrum are shown below.
Name:	Little Bear DAC v1.08 frequency response 48kHz SR.png
Name:	Little Bear DAC v1.08 frequency response 96kHz SR.png
Name:	1khz distortion spectrum.jpg
    Arizona
    1,358
    Great deal at that price. Thanks for letting us know!
    Jul 2011
    SoCal
    1,408
    Nice. Wish it had USB input so I could use it from a computer. I see the seller has a USB to coax converter but that no longer makes it so affordable.
    Nichikuros - Peerless 831735 Nomex + Vifa NE25VTA
    Digger8 - Small compact 8" sub with F3 = 20Hz
    Madison-D and Madison-R - Tang Band W4-1720 + Vifa BC25SC06 or Beston RT003C (TM and MTM)
    Jeffrey - Tang Band W5-704D + Beston RT003C
    Jasmine - Fountek FW146 + Fountek NeoCD3.0 Ribbon in Pioneer BS21 Cabinet
    Irvine, CA
    1,753
    Good to see ya kicking around, Charlie...
    Second one, did I miss something? Wondering if you've considered the "Objective DAC", by that NWavguy... Or some of the cheaper ESS DAC's out there... A set of affordable DACs with the digital only miniDSP processor, would make a nice package...
    Dec 2011
    Bellevue, WA
    336
    Nice find, I wonder if they'll make a balanced version.
    Dec 2011
    Deer Park
    923
    I might grab one and run it through an audio precision to compare our results.
    The harmonic distortion profile is buried. Nice.
    Placentia, CA
    2,568
    A diamond in the rough. Thanks Charlie for showing that good stuff doesn't have to cost an arm and a leg.
    Sep 2010
    NW FL
    4,357
    The eBay seller added your post from DiyAudio to their listing.
    रेतुर्न तो थे स्रोत
    return to the source
    leviathan system thread
    deadhorse thread
    harbinger coming soon
    instagram :: greywarden_13
    in war, victory . . . in peace, vigilance . . . in death, sacrifice.
    Jul 2006
    Davis, CA
    2,221
    Ah, that's no problem. I told him that I wrote about it. I think it is a really great deal, provided you only need coax spdif input (which I do). I told him that there would probably be others who would want to buy one so he has made some more available.
    The ironic thing is that you have to be a member and logged in at DIYaudio to see the images.
    Sep 2010
    NW FL
    4,357
    At $35-40 it they would be a good combo to use with the MiniDSP digital 2x8 box, as it's nearly impossible to find affordable amplifiers with digital inputs and high quality DACs on-board.
    रेतुर्न तो थे स्रोत
    deadhorse thread
    Jul 2006
    Davis, CA
    2,221
    I think you mean this (the nanoDIGI):
    http://www.minidsp.com/products/mini...nanodigi-2x8-k
    Sep 2010
    NW FL
    4,357
    Yeah that one.
    रेतुर्न तो थे स्रोत
    deadhorse thread
    Dec 2005
    coastal AL
    697
    Thanks for the tip! I have about 10 different DACs on my "watch list" on eBay. Just haven't been able to pick one and pull the trigger yet. This is a helpful vote of confidence.
    SEC DIY 2014 Speaker Show is on! *November 8th*
    Wanna win a set of Newform Research R30 ribbons?!?!
    SEC DIY 2014 Thread
    SEC DIY 2012 Speaker Show
    SEC DIY 2011 Speaker Show
    Jul 2006
    Davis, CA
    2,221
    Quote Originally Posted by scottq View Post
    Apart from having pretty good performance and sound quality, it's super easy to use because the "power supply" (the transformer) is included! Just connect the wires, plug in the transformer, and start listening. Some of the DAC kits on Ebay need multiple AC or DC inputs, and you have to add the power supply cost on top of the board cost.
    The only shortcoming, if you can call it that, is that the maximum sample rate for the "Little Bear DAC" is 96kHz so if you want to use a higher rate you are out of luck. Personally I can't tell any difference (audible) once you get above 48kHz, making ultra-high sample rates a non-starter for me.
    Dec 2012
    Vancouver, WA
    144
    Newb question. Does an optical to spdif converter really work or is not even worth it? Trying to find something to go with apple tv or apple airport express.
    Jul 2006
    Davis, CA
    2,221
    Quote Originally Posted by fwiler View Post
    Do they work - yes, definitely. At these sample rates I think that even an inexpensive one (as long as it is powered) will work properly. Both electrical and optical spdif signals are the same.
    Did the $40 DAC get compared to the Benchmark at InDIYana?
    21,569
    Quote Originally Posted by jinjuku View Post
    Nope.
    *InDIYana 2016 event*
