Techtalk at Parts-Express.com   Techtalk at Parts-Express.com
Go Back   Techtalk at Parts-Express.com > Pro Audio / Live Sound Reinforcement - NEW!!
Pro Audio / Live Sound Reinforcement - NEW!! Share ideas and thoughts about getting the best out of your live sound and studio performances...Topics include PA speaker design and construction, pro audio electronics, recording studio hardware, micing, mixing & editing music, and much more.
Reply
Thread Tools Display Modes
  #1
Old 10-21-2009, 11:19 AM
Phil_RC_1 Phil_RC_1 is offline
Member
Default Live recording technique???
Presently we are recording or Church service using the line-outs from the mixer. It does a great job for the sermon but the recording mix of the Worship service (Music) is never going to match the live mix. Without going to the expense of a multi-track recorder etc. etc.,,,I would like to experiment with dual stereo mic's in the house.
1) Which Mic's? Cheaper the better, I'm thinking a pair of condensers. Maybe Dayton EMM-6's
2) Where to mount the Mic's? I'm thinking center rear wall with maybe a 24"x24" foam panel behind the mic's and a foam divider between the mic's to keep some stereo separation?
3) Would there be too much ambient noise or other problems?
Any suggestions of other ways to mic (record) live music?
Thanx, Phil
  #2
Old 10-21-2009, 11:47 AM
billfitzmaurice's Avatar
billfitzmaurice billfitzmaurice is offline
Senior Member
Default Re: Live recording technique???
Thanx, Phil
What you'll mostly get with mics is room echoes. With only two channels the mixer line outs will almost always be better. With multi-tracks you take a feed from the insert/direct out of each channel.
  #3
Old 10-21-2009, 02:07 PM
SpasticColin's Avatar
SpasticColin SpasticColin is offline
Junior Member
If you are using stereo or mono main mix line outputs, then yes, you will definitely have a poor balance between music content and the spoken word. Unfortunately, room mics, especially omnis, will sound like murky, reverberant poo.
A typical live mix (as heard by the audience in the room) is going to end up being a composite of loud sounds coming directly off the stage (drums, electric guitars, a really enthusiastic clergyman) and softer sounds that need amplification through the PA (acoustic guitar, zither, any small child asked to read out loud in front of other people). That's why we have those fader things.
The listeners' ears and brains process and recombine these different sources into one chunk of aural information. Most small to medium size venues will produce off-the-mix recordings that are an acoustical mirror image of the original sources: not much snare drum, a whole lotta zither. Bigger venues are best because pretty much everthing is going through the PA or you're just not going to hear it at all.
Do you have any unused aux sends available? You can set up a nice discrete mix by using post-fader sends (the ones commonly used as effects sends). They will track the main mix but you can also adjust them to greater or lesser relative levels. You can monitor the mix through headphones and also tweak it after hearing a few of these mixes played back.
Using pre-fader sends (like monitor sends) will not work as well because you can pull down a fader in the main mix but it will still pass signal to your recorded mix. It's not impossible this way, but it's a lot more work!
Good luck.
SC
  #4
Old 10-21-2009, 05:50 PM
KevinN KevinN is offline
Junior Member
Lightbulb Re: Live recording technique???
When I dabbled with some mixing for the band my brother was in a few years ago, I used a mini-mixer to add some room mic to the mixer feed. It was an improvement on the direct feed, but time delays between the mics and the PA mix caused issues.
If you were able to record directly to a laptop with an external USB sound card, you could vary the balance (and time delay) between room mics and direct feed during editing. I imagine this could sound pretty good with directonal mics placed in the right spot (maybe near the front of the room?).
  #5
Old 10-21-2009, 07:19 PM
Member
Quote:
I'm just a bit stubborn and like to see (Hear!) things for myself, so I may try it anyway, using a sound absorbent "shield" to help cut down reverberant room echoes, noise etc.
Our Problem exactly. We only use the music recordings for critique, but it would be great if they were a little better balanced. The sermon is used on our web-site and could still be recorded from line outs of the mixer.
Good luck.
SC
Great idea, I haven't thought of that, Deffinitely something to look into. We have 2 effects loops, one is setup as a chorus effect that is pretty-much unused. Thanx for the input.
Thanx to all. Now I at least have a couple things to try.
Phil
  #6
Old 10-28-2009, 03:15 AM
henrythomas henrythomas is offline
Junior Member
Hi to all,
Such a good recording techniques.
Thanks for this informative information.
__________________
bluetooth kopfhörer
  #7
Old 11-01-2009, 01:06 AM
WmAx WmAx is offline
Senior Member
The Daytons, like all super small condensers, will have high noise levels, relatively speaking, especially a problem in mid or far field mic placements.
Behringer's B-5 is a superb unit. Very low noise, extremely flat response (nearly +/- 1.5db typical in the audible band - verified by 3rd party measurement), and high build quality. Comes with two different mic capsules: one for cardoid and one for omnipolar, allowing you to adapt to the situation/circumstances of the recording session. Both are excellent with very flat response.
I know of no mic that is really comparable without spending many times the amount of $$.
Note: this type of condenser is relatively fragile - and not suited all that well to typical live performance recording scenarios such as rock bands, etc.. It is more suited to things like classical/jazz recorded in such a way as to sound as realistic as possible using mid or far field recording methods. Also makes a superb studio mic.
-Chris
  #8
Old 11-05-2009, 07:35 PM
Member
-Chris
I started considering this type of recording after reading Linkwitz's site. He has made some apparently decent live recordings using condenser capsules. Head capsule mic
Those Behringers are pretty cheap, I might be willing to take a gamble at that price.
What do you think about the matched pair C-2 or C-4's??
  #9
Old 11-06-2009, 10:41 AM
Senior Member
The B-5 is optimized for flat response, and comes with two capsules for maximum versatality(cardoid and omni), so due to these two things, I only recommend the B-5. Also, I have not measured the other two models you mentioned.
-Chris
  #10
Old 11-09-2009, 10:50 PM
glenfoxman glenfoxman is offline
Junior Member
I am partial to using minidisc for recording live performances. If you plan to record live music as well as comedy shows I highly recommend that you get a quality mic as well as battery module or mic preamp to reduce distortion and clipping.
_______________________________________
Website I designed for payday loans ottawa company.
  #11
Old 11-10-2009, 05:50 PM
meep meep is offline
Member
echo that on the B-5. Seems like they also sold a matched pair (C-?) for $50, same as the B's but a single capsule. Good bang for the buck, though mine developed a loose connection at the xlr. needed touch-up solder.
also echo the room ambience atop board feed. The aux-send mix is great if you have the sends. It's hard to do a good recording in a mixed environment where some sound (drums, stage amps) is natural while others (vocals) is PA'd.
I would:
1- mic for ambient. Stereo.
2- mono board feed.
3- experiment with mic placement. Probably better up close considering room noise, reverberation, time delay.
4- experiment with mic positioning--- seperate L-R or an X configuration.
I have done this even with up to 5 piece dance bands and had decent results.
  #12
Old 11-14-2009, 12:19 AM
Member
-Chris
I guess I'm gonna find out . Got two B-5's on the way. Now to decide how to mount them. I'm still thinking the best chance to avoid excessive room noise and rumble is to somehow shield their periphery to limit the ambient noise, Maybe?
Until I get this worked out, I'm going to keep recording the way we have been, Sooo,, I'll have time to experiment and get it worked out. If all else fails, I guess the mic's will work well as overheads for the drums.
Thanx Guys,
Phil
  #13
Old 11-17-2009, 10:38 AM
Member
don't shield them. They should have ports on the sides to enable the directional pickup. If you do shield them, it should be a large flat absorbant surface BEHIND THEM, not next to them. But don't overthink this. Put them on stands first and mock up everything. Lots can be achieved by being simple and going thru the basics first.
M
  #14
Old Yesterday, 02:22 PM
ampnation ampnation is offline
Junior Member
I'm a noob when it comes to live sound but I did some reading based on my desire to offer multitrack recordings to bands that use my PA system. I was looking at using the Fostex or Alesis 24 track ADATs. One aspect was that I wanted to record the crowd reaction and read a great article that talked about using a couple of shotgun mics. It doesn't sound like the OP necessarily wanted crowd noise but I am thinking they might be able to pick up that listener perspective he's looking for. (or she) The suggestions in the article were for AKG mics which were several hundred dollars each, but I saw an SM Pro Audio em9600 shotgun for $89. Couldn't find reviews of this mic though.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
* on most orders over $49
Join Us
Parts-Express.com on Facebook
Parts-Express.com on Twitter
Parts-Express.com on You Tube
Our Sales Flyer Is Available Digitally
Update Your Home Theater
Home Theater Receivers and System
Power Up Your System
Amplifiers & Subwoofers
New From Dayton Audio
Full Range Reference Drivers
High Quality German Engineering
High Power Subwoofers
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 1996-2009 Parts Express, All Rights Reserved
