Description |
Sold!!! Thanks for looking... Hypex, AS2.100 DSP 3 way high-quality low noise processing with two channels of 100w amplification for mid and tweet Never used and virtually new. One plate's screw holes slightly enlarged to accept #8 screws but was never mounted. $300 for the pair FREE SHIPPING The AS2.100 is a plate amp for use in powered speaker systems. As an active speaker controller,a AS2.100 can form the basis of a powerful active two-way monitor. In stereo mode one AS2.100 will power an active master / passive slave pair. Finally, the module may also be used as a one-way 140W amplifier. All signal processing, including volume control, is done using the on-board DSP (digital signal processor).Figure 1 shows the block diagram of the amplifier. When two modules are used, the second unit slaves to the first unit (master) through a link cable. The link cable (a stereo mini jack cable) carries both the right audio channel and control data. This way, both units respond to the masters control panel. A PC controls the AS2.100 through the USB port. This connection is used to upload the configuration and filter settings. An optional board permits use of the USB link for audio as well as an SPDIF link. In digital mode, master/slave linking is done through the SPDIF in/out connections instead of the mini jack cable. Features:
Hypex AS2.1 DSP 2 way plate amplifier pair
