***SOLD***
$75 shipped from Costa Mesa, CA.
COMES WITH: (2) speakers, (2) Audioengine rubber speaker stands ($30 value), upgraded 6' Belkin speaker connector cable, 15v power supply. (Sorry about font inconsistencies not sure what happened there)
The speakers have a rear-mounted volume control knob that also acts as on/off switch, 2 AUX inputs (one RCA and one 3.5mm). These speakers were used maybe 2 hours max. Still being broken in. I had them in my office to listen to music at lunch, however I am usually busy at lunch now so these don't get much use anymore. Many of my coworkers would comment on the sound quality, and sound quantity of these little speakers. In a small to medium room the sound is huge. About as neutral as any other professional monitor at a similar size. You cant DJ a wedding with them, but they will fill your house with clean sound. Add a subwoofer and you will have a killer setup.
They are from a smoke-free home/office. There is one very tiny blemish on top right corner barely noticeable (pictured), other than that they are in new condition. I thought I had the original box, but need to look better for it. It's around somewhere, but no guarantees. Any questions please ask.
DEMO VIDEO: https://www.youtube.com/watch?v=RmfFIN1T8YI
***SOLD***
Drivers | Low-Frequency Driver: 3.0" (7.5 cm) cone High-Frequency Driver: 0.75" (19 mm) soft dome |
Frequency Response | 110 Hz to 20 kHz (+- 3 dB) |
Crossover Frequency | 2.65 kHz |
Inputs | 2x RCA 1x 1/8" (3.5 mm) stereo mini |
Input Sensitivity | RCA: 360 mV Stereo Mini: 650 mV |
Output Power | Per Monitor: 15 W RMS Total: 30 W RMS |
Total Harmonic Distortion | < 0.1% (@ 1 W, 4 Ω loaded, 20 Hz to 20 kHz) |
Signal to Noise Ratio | ≤ 90 dB (A weighted) |
Power Supply | DC In: 15 V |
Dimensions (H x W x D) | 3.9 x 7.2 x 5.1" (10.0 x 18.5 x 13.0 cm) |
Weight | Right Unit: 3.28 lb (1.49 kg) Left Unit: 3.17 (1.44 kg) |
***SOLD***
