***NEW IN BOX*** (2) Dayton 2-way 3K crossovers. I accidentally kept them past the return point. I would like to sell them both at once. $40 for both, free shipping in the lower 48 US. [email protected]
(2) Dayton Audio XO2W-3K 2-Way Speaker Crossover 3,000 Hz (NEW IN BOX)
Dayton Audio XO2W-3K 2-Way Speaker Crossover 3,000 HzThe Dayton Audio line of 2-way crossovers were designed using a second order (12 dB/octave) Linkwitz-Riley alignment. Dayton Audio metallized polyester film capacitors are used in both the high and low pass sections. 18 gauge inductors were used to keep DC resistance to a minimum. A unique design feature of the low-pass section allows use of 4 or 8 ohm woofers, perfect for building D'Appolito style or multi woofer 2-way systems. The high pass crossover frequency is rated for an 8 ohm load. All components are glued or fastened down to eliminate buzzing and vibrations. The high quality blue PC board uses a back plate for added rigidity and eyelet holes for easy mounting. Available in a variety of crossover points. 300W power handling. Board measures: 6-1/2" W x 4-1/4" H x 1-3/8" D. Terminals are 0.205".Tags: None
- 1 like
