MSRP of US$ 7,995.00
Asking $3,000
Evans/Augusta, GA 30809 local pickup
Uses Accuton cell drivers along with a Scanspeak 18wu. The cost of the raw parts is:
Accuton Cell C25-6-158: $530 each
Accuton Cell C90-6-724: $710 each
Scanspeak Illuminator 18WU/4747T-00: $339 each Tested in Voicecoil to be 10mm xmax, beyond specification
Raw driver cost for a pair of speakers: $3158, not counting tax, crossover parts, cabinetry. The Vimberg Mino used the midrange and tweeter to great effect in Stereophiles measurements.
Here's the list of features:
Asking $3,000
- Made in the USA cabinetry
- German top of the line driver technology
- Accuton Cell midrange/tweeter array
- Low parts count crossover
- ERSE air core inductors
- Mundorf capacitors and resistors in tweeter signal path
- Mundorf resistors
- Cardas soldering all point to point from binding posts to drivers
- High-end Supra wiring
- Cardas patented binding posts
- Custom engraved binding post plate and port ring to lower resonance.
- Braced baffle and sidewall technology
- Flared port for low noise
- Proprietary damping material to turn vibration into heat
- Size: 8.25"W X 35"H X 11.5" D (cabinet tapers back and slopes 5 degrees)
- Frequency Response: 38hz-25khz
- Minimum Power Requirements: 35watt (tube) 50watt (solid state). 86db/2.83v/meter
- 3-way fullrange loudspeaker
- Tweeter/midrange array decoupled by expanding o-ring driver technology mounted to custom aluminium mounting plate
- 1 x 25 mm Accuton™ Cell ceramic tweeter
- 1 x 90 mm Accuton™ Cell ceramic midrange
- 1 x 184 mm Illuminator™ woofer, long excursion design with underhung voicecoil
- Bassreflex port design for lowest port noise with dual flared ends.
- Height adjustable isolation outriggers with cone floorspikes included (not shown)
- impedance: 4 ohm (lowest point: 3.1 ohm at 100Hz)
- Standard veneers include: Cherry, Walnut, Ebony (faux)
- Weight: 2 x 65 lbs. (plus packaging)
