New Test CD
  • New Test CD
    Was wondering does anyone know if the new test cd is available or if there is a date when it will be?
    Thanks
    Jeff
    Re: New Test CD
    What new test CD? Where did you hear about this? What does it do that the current one doesn't?
    I'm not deaf, I'm just not listening!
      Re: New Test CD
      My disc has only 4 tracks on it, the new one has 19 tracks.
      Test CD Track Listing
      (these are the tracks for the expanded Test Signals CD, to be available in 1st Qtr, 2012. The version 1 Test Signals CD contains only longer versions of the first four tracks)
      Track 1: Monophonic Pseudo-noise sequence
      Track 2: Monophonic Short Sine Sweep
      Track 3: Monophonic Long Sine Sweep
      Track 4: Monophonic Bass Sweep
      Track 5: Left Channel, Pseudo-noise sequence
      Track 6: Left Channel, Short Sine Sweep
      Track 7: Left Channel, Short Sine Sweep, bass removed
      Track 8: Left Channel, Short Sine Sweep, bass and midrange removed
      Track 9: Left Channel, Long Sine Sweep
      Track 10: Left Channel, Bass Sweep
      Track 11: Right Channel, Pseudo-noise sequence
      Track 12: Right Channel, Short Sine Sweep
      Track 13: Right Channel, Short Sine Sweep, bass removed
      Track 14: Right Channel, Short Sine Sweep, bass and midrange removed
      Track 15: Right Channel, Long Sine Sweep
      Track 16: Right Channel, Bass Sweep
      Track 17: Warning
      Track 18: Left Channel, 50 Hertz Tone for voltage measurement
      Track 19: Right Channel, 50 Hertz Tone for voltage measurement
      Jeff
        Re: New Test CD
        I knew there was a new cd coming but didn't realize how awesome it is goig to be. :D
        ErinsAudioCorner.com
          Re: New Test CD
          I guess I didn't realize there was an "old" CD. What you described with 19 tracks is what I have. I had no idea since it matched what was described in the help file. The Omnimic software also came with FRD's to compensate when using the high pass or bandpass sweeps.
            Re: New Test CD
            So how does an early adapter acquire this CD?
            Any way PE could make it available for download?
            http://www.diy-ny.com/
              Re: New Test CD
              I am quoting this from another post from Bill Waslo:
              Originally posted by bwaslo
              Hi,
              I heard people were asking about the new test signal CD. If you want, you can download the wav files for it from here, for a while at least
              OmniMic%20Signal%20Test%20CD%203.zip
              But be warned -- it is a 251MB download, so it will take a while unless you have a really fast connection. Probably not likely to work on a phone connection.
              After downloading you'll have to:
              1) unzip it (it's a zip file)
              2) use a CD burn program (Nero, Sonic, etc.) to make an Audio CD Disk, select the files in the proper order (by their numbers) into it and be sure to burn with "normalization" turned OFF (if that option is given).
              Same signals as original CD, but there are Right-Only and Left-Only versions of most, as well as some bandlimited versions and a level-setting tone. See the last section of OmniMic Help (the menu in the program) to see the file listing.
              The 5.1 DVD isn't compiled yet. Enjoy,
              Bill
                Re: New Test CD
                Thank you!
                (2 minute download) :D
                  Re: New Test CD
                  Thank you!
                  You're welcome Face...
                  I am looking forward to the 5.1 DVD later this year.
                    Re: New Test CD
                    It appears track #16 is corrupt.
                      Re: New Test CD
                      yep. noticed the same thing.
                        Re: New Test CD
                        I got some error when extracing, but all the tracks are there and are fine, including #16.
                          Re: New Test CD
                          I could not download Track #16 so I skipped it in the download. All other tracks are there so what do I miss not having 16?
                            Re: New Test CD
                            same problem with track 16 also
                            Jeff
                              Re: New Test CD
                              i just tried to download and the link sends me to 'FORBIDDEN'.
