Modify microphone capsule
  • Modify microphone capsule
    Hello Bill, I was think about modify microphone capsule in the Omnimic, for example like Linkwitz measuring microphone. When measuring the distortion in the near field, it would be interesting.
    Richard
    Re: Modify microphone capsule
    It is already configured as source follower.
    Free & Free-form simulator/designer for Passive Crossovers
    SynergyCalc 5: design spreadsheet for Wooden horns and DIY Synergy Waveguides
    Super easy and cheap to make high performance sound diffusers
      So the next series Omnimic will of this treatment?
        What part of "It is already configured as source follower" did you not understand?
        "It suggests that there is something that is happening in the real system that is not quite captured in the models."
          mh, I understand, I asked because has Omnimic max. 127 dB SPL, and after the treatment but could be about 140 dB, but I quietly
              Available capsules now have higher sensitivity (unfortunately) than the older ones, and using source follower gets the sensitivity back down only to about what the old WM62 capsules did. Distortion is improved, but max signal handling is about what older capsules did with grounded source configuration.
              These type capsules are optimized for low noise (higher sensitivity) rather than high SPL handling. I'd really like if they were made less sensitive, but we'd have to get the quantity up into the several tens of thousands to get anyone to make them.
                ok, thank you Bill
