X-mas wishlist! Support for two microphones and vector addition ( port+driver)
  • X-mas wishlist! Support for two microphones and vector addition ( port+driver)
    As I like to fiddle with horns, pipes and bass reflex speakers. I would like to be able to add two near field mesurements to one sum. For that you would have to add the two radiating surfaces (as diameters or surface units like square cm) and a path difference between them. Path differences hardly matters for say a 30 Hz port as 1 meter is less than 1/10 wave lengh but if you have unwanted harmonics/resonances in say 150 Hz then it matters how much it adds or substract due to phase.
    The convenient way would to be able to run two microphones at once and to sum on the fly. A cheaper option would be to measure twise and for example assume that the driver and port are 180 degrees apart at peak port output, but that is asumptions as opposed to measurement.
    Any hope for such a feature?
