I recently made the plunge and purchased Omnimic (SW ver 4.68). I've used HolmImpulse for the last couple of years, but thought I'd give Omnimic a try after reading all the glowing reports. I've given it a test run and have two questions:
- Is there any way to adjust the vertical scale in the impulse window? I'm having trouble seeing my initial reflections after Omnimic autoscales the window. Being able to enlarge the impulse window would work too.
- When I select a gated measurement by clicking in the impulse window I don't get the response I expected. For example, when I click on 4 msec I expected the graph to start at 250 Hz ( 1/ (4 msec) = 250 Hz). However, the graph starts much higher, around 600 Hz IIRC.
Thanks,
Ed ( the "e" in ernperkins)
Thanks,
