phase question
  • phase question
    hello,just getting started using Omni mic and need some advise on what my phase should look like in relationship to the frequency response measurement. anyone that can shed some light on this would be great! thanks!
    Re: phase question
    Looks OK to me (never used Omni mic before, though).
    5ms SEEMs a bit long. You'd basically need to have nothing closer to your mic/DUT than about 6' (which would preclude 12' ceilings w/the measurements taken 6' off the floor) to be reflection-free.
      Re: phase question
      Is your driver on a very narrow baffle?
      You need to measure the drivers individually with phase then add them with phase so you can see the alignment.
        Re: phase question
        the baffle is about 2" wider than the woofer on ea side. Click image for larger version
ID:	1165336 thank you for the info,i will measure like you said and see what I come up with.
          Re: phase question
          ok I had the mic about 3' in front ,I have low ceilings less than 8ft and the speaker is about 4ft off the floor.
            Re: phase question
            Better gate (for surfaces 4' away) would be 3.33ms, which limits data credibility to about 300Hz.
