Hi all,
I'm having an issue with my XENYX 1832FX mixer. If I knew what component to replace, I could easily do it myself, but I'm not quite sure where to start!
Here's the issue:
Normally, I plug a set of studio monitors to the mixer, and then have my audio out from my PC run to the mixer via usb. This setup has been working perfectly for about a year. However, upon power-up yesterday, I noticed that my right monitor had very loud and choppy noise/static. Immediately I thought that there might be something wrong with the monitor or the cable, but after checking both these things, I realized the problem is elsewhere. I then suspected grounding, but the the noise is only on the right channel, and I did try different wall outlets, so that's not the problem.
Even with no inputs (just the mixer plugged in and the monitors attached to it), there is still a lot of hissing on the right channel! I've come to the conclusion that there is something wrong internally solely with the right output channel; maybe something popped/blew up inside? The weird thing is that everything was working perfectly during my 2nd last session, and no settings or knobs were tampered with at all.
Can someone advise?
Here's the issue:
Can someone advise?
