Vocal PA array with Peerless 5.25 HDS
  • Vocal PA array with Peerless 5.25 HDS
    Hi there, my first post here on the Pro audio forum ...so easy on me...
    My band is in despearte need of a vocal PA, and I had bought a few speakers on buyout some time ago. On hand I have:
    (4) HDS Nomex 5.25" 830911 - truncated frame, ented cone, 8 ohms
    (4) HDS Nomex 5.25" 832873 - truncated frame, 8 ohms
    (2) Vifa BC 18s49-08 6"
    My thought was to slap four of these (into each speaker) for a small vertical array...lightweight for easy transport. I don't want to sink money in elaborated x-over, it would be all full range wired two series (16-ohm string) then each string parallel for a 8 ohms total impedance. These extend to about 6k hz in the freq. response chart so would be OK for voice. Maybe later add a 1st/2nd simple crossover to a tweeter/horn to take care of 6khz and above. Our Yamaha MG mixer has bass/mid/high EQ so that would help. They'll be driven by a Peavey 120 w/ch amp. used for samll practice/venue. The Peerles require about 7.3 liter each on a vented box or go smaller into a sealed cabinet.
    Also, any problem substituting in one of the 16-ohm series string with the 6" Vifa used in series with one of the HDS Peerles (16 ohm total)
    Before I go any further thought I would post here first
    I'm I wasting my time? or is there some potential
    thanks
    Re: Vocal PA array with Peerless 5.25 HDS
    These aren't PA drivers so if your band makes absolutely no noise whatsoever(everybody on ears, electronis drums, and no instrument amps at all) then you'll be able to hear the vocals, but if even one guy brings so much as a 15w practice amp the vocals will be completely drowned out.
    Paul O
      OK Paul that was a good one (LOL)...I guess that kills the idea...
      Back to using our backups (Line6 guitar amps) w/12" driven by our yamaha mixer for the next upcoming gig. It worked good last time.
      -cheers
        It is not DIY but the RCF Art 312a can be found on sale for around $450 right now. It hangs in there with the $1200 boxes and is regarded as a good value for a vocal pa.
          If you want to build something that is REALLY GOOD.
          Please take the time to check out this web site. I have heard some of his designs and they ROCK. He knows what he is doing and there is nothing better than a horn loaded enlosure for pro sound!!!
          http://www.billfitzmaurice.com/
          tron
          Real amplifiers GLOW in the DARK!
          Nothing kicks A$$ like Glowing Glass!
            Originally posted by revelator View Post
            ...My band is in despearte need of a vocal PA,...My thought was to slap four of these (into each speaker) for a small vertical array...lightweight for easy transport. ..I'm I wasting my time? or is there some potential
            You didn't mention the typical venue you play...
            I guessing that the dimensions are not appropriate for a line array;
            and IF it was as Paul said "These aren't PA drivers"
              Typical venue is small (varies),last time it was a restarurant/bar. Except for the drummer (which we have to beat periodically to keep it quiet) , our four-piece band does not play loud and the PA would be strictly vocals. At the moment we only have a single Peavey SP112 ... and on vocals it sounds muddy crappy anyways...on top of that the horn is blown.
              I was thinking that four fullrange mid/woof Peerles would take me into the 90db+ range for vocals only since their freq respose is relatively flat...But I know there is more to it than just slapping four of these together in a vertical array due to freq. cancellation? I don't know??
              any more comments thanks...
                So the distance from band to audience is short & close?
                LOL I'm not surprised...
                A SP112 was designed to meet a price/performance point.
                ( FWIW: I heard much better boxes in that config. )
                  Also note:
                  Four 5.25" drivers is not a line array. It will not behave like a line source at any frequency in its passband.
                  (Somebody needs to tell that to Galaxy Audio, which makes a product like this).
                  Best Regards,
                  Rory Buszka
                  Taterworks Audio
                    Originally posted by Taterworks View Post
                    Also note:
                    All sources are both line sources (operating in the nearfield) and point sources (operating in the farfield) at some portion of their bandwidth. In any event the main reason for using line sources in PA is not realizing the nearfield condition, it's vertical pattern control with horizontal pattern uniformity. Four 5.25" might not seem all that effective, but experience proves otherwise. For example:
                    http://billfitzmaurice.info/forum/vi...p?f=30&t=14042
                    But you still need to either use pro drivers or at least twice their number with hi-fi drivers.
                      I feel it's more important to find the appropriate design that produces the desired/needed dispersion pattern.
                      That's why McCarthys pragmatic focus on what the source does ( dispersion pattern over distance etc ), rather that what it is called: is an objective practical approach.
                      The combined Sd of 4 5.25" is about the same as a 10" driver: That may be enough displacement for some; it is insufficient for the needs of others.
                        It is not a question of displacement, but of efficiency! I am sure that is what BFM's statement alluded to.
                        “I cried because I had no shoes until I met a man who had no feet”
                          It is not a "free lunch" without considerations;
                          As the line of drivers is extended - the coupling bandwidth is reduced.
                          ( Ref: Loudspeaker handbook and Electroacoustical reference data By John Eargle )
                          For (4) 5.25" drivers ctc: 1291Hz
                            So why not simply repair the horn driver? The RX22 diaphragm is widely available.. http://www.parts-express.com//pe/psh...94-322&ctab=14
                            Paul O
