A friend is wanting to use these on his guitar cabinets. He will be going from 1/4" to speakon. Which input jack and such do I need to look at?
speakon connection
Re: speakon connection
Speakon connectors are for speaker cables, not guitar amp inputs. If you are in fact, talking about the speaker lines - just take the output from the amp (whatever type of connector) and run it to the speaker (whatever type of connector). I've never used speakons before, but I like the idea that they lock in so that they can't be pulled out of your speaker by accident.
We are building him a new cabinets. The speaker connection at the amp is 1/4in. He wants speakon connections at the cabinets. There are 2 cabinets so he can use 1 or depending on where he is playing. He is wanting to use the 90deg units. I will make the cables myself to keep them as short as possible. I just need an understanding of which males to use with which females.
Originally posted by isaeagle4031I just need an understanding of which males to use with which females.
Originally posted by wg_ski View PostIt's confusing as the panel mount JACK is considered "male" and the PLUG on the cable considered "female". Use NL2Mxx (or NL4xx) on the cabs and NL2Fxx or NL4Fxx on the cable. You may need to go to 4 pole to get a 90 degree connnector. 4 pole is compatible with 2 pole - the other two just won't go to anything if you mate a 2 with a 4. Personally, all I buy are 4 pole plugs or jacks - just to keep one type in stock that works for everything.
http://www.neutrik.com/en/speakon/sp...rs/stx-series/
http://www.neutrik.com/en/speakon/sp...rs/stx-series/"Our Nation’s interests are best served by fostering a peaceful global system comprised
