Re: PA system rebuild project
Have you checked out Welters design?
I was skeptical of the driver choice but it pulls good numbers below 40hz compared to traditional 18 subs.
There is a comparison at the link posted above with a SRX728, EV QRX, and EAW SB1000.
"These popular dual 18''s all have a large upper sensitivity advantage compared to the Lab 2x12''.
All the cabinets still adhere to Hoffman's Iron Law, their sensitivity in the 30 to 40 Hz range is very similar.
Below 40 the difference between the dual 18s and the 2x12'' is only about 3 dB, so a pair of the 2x12'', which take up less space than a single dual 18, would have about equal sensitivity down low.
However, the 728 can not take close to full power down low without exceeding Xmax, while the Lab 12s can. Four Lab 12 can take the same power as two of the JBL 18'', and will have less distortion down low.
From previous listening experience, I'd reckon the JBL to be cleaner than the other two dual 18s when pushed hard.
The Lab 12 design, having very flat response, does not require out of band EQ, so it ''plays well'' with with any top cabinets that have flat response at the crossover point.
Makes getting things to sound ''real'' a lot easier, especially if setting crossover points ''by ear'', or using crossovers that don't have delay, EQ, or the ability to have different crossover frequencies between low and mid.
Art Welter"
Originally posted by billfitzmaurice
View Post
Art Welter"
