I have an idea for a scalable DIY PA system that I would like some feedback on. It would start with Econowaves, in particular this variant: Econowave DSP
I want to use active crossovers for efficiency and using the MiniDSP to implement the crossovers adds the benefit of flexibility.
The idea is that for low volume applications, you could use the Econowave DSP as-is, then when more power is needed the crossovers could be changed to higher order and the 12" would be crossed over with a sub.
For even more power the Econowaves would be doubled and stacked, with the lower ones inverted (horn on bottom), the 12s in parallel and the lower horn not used. It this configuration by my estimation SPL output at max power for the mids would be about equivalent to the max SPL output of the compression driver.
The sub would be an Eminence Sigma 18 in a 3.3 cubic foot sealed cab, operated Bag End style below resonance with a DIY dual integrator based on this design
The sub crossover point would be 91.4 Hz based on the resonance frequency of the sub, 12 dB/octave so the 12s would be configured to have a -3dB point of 122 Hz.
Based on the driver specs I did this power/spl comparision I did.
D220Ti: 109 dB 2.83V/1m, 80W RMS max
equivalent to 640W 100 dB 1W/1M
Beta 12: 98 dB 1W/m 250W max
2 in parallel, 101 dB 1W/1m 500W max
Sigma 18: 99 dB 1W/1m, 650 W max
My big question is what are the power limits when you take into account the small sealed boxes and the low crossover point for the D220Ti? Any thoughts about the concept in general?
