Need advice on finishing up my PA system
I have 2 Eminence DEFINIMAX™ 4018LF 18 inch sub speakers mounted in 2 reflex cabs
Nominal Basket Diameter 18", 457.2mm
Nominal Impedance* 8 ohms
Power Rating**
Watts 800W
Music Program 1600W
Resonance 32Hz
Usable Frequency Range 36Hz - 0.2kHz
I have a QSC PLX 3402 powering the two subs 700 watts per channel @ 8 ohms. I have a DBX 223XL 2 way crossover and a DBX EQ. I want to use this system to power our bands practice sessions in a 24’ X 30’ basement. We play heavy rock, mic everything, use Roland v drums and also DI the Ampeg SVT 7 bass guitar rig. I need to build some mid high cabs to go with the subs and amp I have. I also have a QSC RMX 850 power amp to run the mid high cabs. What would be the best speaker, horn and xo setup for the top end? I’m thinking a 12 inch 2 way would do the job. The subs sound good XO at around 100hz. Any advice from the pros here would be great.
Thanks, Ken
Power Rating**
Watts 800W
Music Program 1600W
Resonance 32Hz
Thanks, Ken
