So I am rumming a QSC 850 with a psa 1.1 preamp. The issue is a low signal unless the pre and volume on amp are cranked pretty high. The yellow signal light barely lights up unless I crank the volume on the amp up. Is the signal light suppose to light up more when I adjust the volume on the amp up? I think it should light up more with the signal incoming to the amp and only the signal going to amp but it also lights up more when the actual amp gets turned up.
Also until I get the signal light to stay lit most of the time things just don't sound good (no attack on bass, guitar sounds weak) Issue is once the signal light really starts to light up and things start to sound good it is pretty loud for practicing at home.
