Duratex
  • Duratex
    Many of you speak of highly of Duratex. I see the banner offering Duratex in a one quart bag, and would like to try it on my next cabinet.
    Is this a fumy product? Should I wear a mask?
    Will I need to putty and sand my screw holes?
    Does the product bond well to plywood and mdf?
    What's the curing time?
    TIA,
    Jeff
    Re: Duratex
    Duratex is a great project. No fumes, no mask needed. I would fill screw holes. Treat end grains with a 50/50 coat of wood glue/water. It adheres to about anything. 2 coats and it is great.
    Videos: http://http://www.youtube.com/watch?v=iuav56tGIE4
    http://http://www.youtube.com/watch?v=Gr7ZMGSspNs
      Re: Duratex
      Echo all of the above- I've had very good experiences with the roller grade DuraTex.
      For me at least, it's worked out best to apply over a low/semi-gloss black undercoat... and on MDF cabinets, to begin the process with shellac-based primer as a basecoat (tip o' the hat to members here who suggested this approach- kanemack, and others IIRC).
      Great stuff, goes a looong ways.
      Ed Henderson
        Re: Duratex
        +1
        it becomes tack free really quickly, takes a little longer to fully cure
        i like the shellac sealing a little more(but then there are fumes)
        practice on a piece of scrap to get the texture you want
        "As you start traveling down that road of life, remember this: There are never enough comfort stops. The places you’re going to are never on the map. And once you get that map out, you won’t be able to refold it no matter how smart you are." -kermit the frog
        a good place to check out http://www.midwestaudioclub.com/
          Re: Duratex
          Thank you! Gonna try it on my new twin 12" 2-way tops. Tired of carpet...
            Re: Duratex
            Wear junky clothing. Duratex won't wash out.
            No odor, dries very quickly to a really tough finish. It's meant to be applied directly to wood (no priming or anything). Great stuff. Probably the easiest finish ever.
            Statements: "They usually kill the desire to build anything else."
              Re: Duratex
              We did a live Duratex application at the Dakota DIY: https://www.youtube.com/watch?v=ItEFdZuhNAg
              Additionally, Acry-Tech has several videos on youtube that may help. Here's their channel: https://www.youtube.com/channel/UCnD...71rrPlNwGeHJIg
              As the others have stated, it's a great product (almost no VOC) that doesn't require end grain sealing as it's both a primer/sealer + paint. After about one week, it will be hard as a rock. However, it dries to the touch in minutes, so make sure you work fairly quickly when you apply it and DO NOT apply it in the sun as it will dry way too fast. You can of course put it in the sun to speed up cure time.
              Have fun.
              Bryan K.
              Midwest Audio Club
              Speedster | Sub Attaché | The Wildeman | Sean's NLA Towers | COÜGAR, COUGAR II and COÜGAR JR | Triton | Lithium | J-Boom | Trym MLTL | Docere MLTL
                Re: Duratex
                You can fill any imperfections with drywall mud and sand.
                Then put up to 3 coats per hour,(when you apply it at the picnic table in the sun with a good breeze). You can make it smootherer if you sand the first couple of coats or rough if you don't.
                  Re: Duratex
                  Thank you all for your stories and advice. Arlis--great photos. I'm excited!
                    Re: Duratex
                    Just wondering if anyone has any info/thoughts/opinions on the Duratex Acoust-X for cabinet interiors. I am about to order a gallon of Duratex from my Canadian supplier, and they also sell Acoust-X at $32/gallon.
                    I'm not deaf, I'm just not listening!
                      Re: Duratex
                      Bryan Keane used it on his Docere MLTL build. Hit him up for his thoughts on it.
                        Re: Duratex
                        As much as I love DuraTex I'd pass on the Acoust-X. It can't work as well as traditional damping materials.
                        www.billfitzmaurice.com
                          Re: Duratex
                          I used it in the construction of a constrained layer baffle and for that it worked well. I can't speak to its effectiveness as a traditional damping layer inside of a cabinet. It's an interesting product though....it adheres very well but doesn't cure hard like Duratex.
                          Bryan K.
                          Midwest Audio Club
                            Re: Duratex
                            Thanks guys, I decided to pass on the Acoust-X. I do have a gallon of Duratex on the way, I've got a few fun projects coming up that I'll be using it for.
                              Re: Duratex
                              That gallon will go a long way. I just put 4 coats on my latest build which was just over 30 sqft per coat, and used about 1 quart. I LOVE that crap.
                              Your results may vary.
