Hello everyone! this is my first post on the site an after some looking I could not find what I hope to be a relatively simple answer.
I am building a large 24 x 45 x 18 (BFM Tuba45) folded horn LAB12 Loaded Sub for PA use. However, I'm sure I'll realize that for the occasional house party, it will NOT be needed.
I would like to build a small but potent ported 12 for a few reasons:
-much smaller than a horn loaded box and easier to move (even the smallest BFM sub - Tuba24 - is still 24 x 24 x 16 and only plays down to 45 Hz)
-still flat to mid 30's (DJ use; house/trap/dubstep)
I don't need anything in the 20 Hz region so this would definitely be considered more of a PA build than a HT build. Therefore, if I can sacrifice that EXTREME low end for a little less box volume, I'm all about it!
Last notes, I have heard that the LAB12 is an excellent driver that can handle a beating, but since I wont be horn loading in this case, should I opt for a more efficient 12? (LAB is something like 89 dB sensitive) I have heard that the LAB makes a hell of a lot of nice noise when you throw enough power at it in a small boxes and powering it wont be a problem.
I will be driving it with the same QSC GX5 that I run the rest of my system with.
THANKS FOR THE HELP GUYS!!!
