Harman Kardon HK3770AM-Z $315
  • Harman Kardon HK3770AM-Z $315
    I think these factory reconditioned products are a steal! I have purchased two over the years and never had any problems. As a mater of fact I would think you are actually at lower risk of getting a dud this way than new purchase. The HK37 series stereo receivers have always been solid products for the money in my opinion. And the 3770 for $315 bucks is hard to beat I think.
    https://www.harmanaudio.com/search_b...70AM-Z&status=
    At a glance:
    Striking Harman Kardon design leverages quality materials in a 2-channel, 240-watt stereo receiver with ultra-low distortion.
    A high resolution DAC, featuring a 24 bit/192kHz sampling rate.
    Complete connectivity, including a phono input, AM/FM radio, digital audio inputs (1 coaxial/2 optical), home network DLNA®, vTuner Internet radio, iOS Direct with built-in DAC (digital-to-analog converter), or audio file play via USB.
    Cutting-edge connectivity options, including Bluetooth® for high quality audio streaming from a broad range of devices.
    The Harman Kardon Remote app provides control through iOS and Android platforms as part of the Harman Kardon ecosystem.
    The power derived from the HK 3770’s high-current amplifiers provides you with what you need to access the high quality sound available from all your playback sources and electronic devices, delivered to your choice of speakers.
    A high resolution DAC, featuring a 24-bit/192 kHz sampling rate.
    Get the most out of your signal path with a high resolution, 24-bit, 192 kHz DAC – which helps marry analog to digital in a stereo receiver providing you instant access between devices. In other words, your receiver has the option to receive everything that’s available to you in analog or digital form – redefining the term ‘stereo receiver’ while transforming your system into a true entertainment/infotainment center of your design.
    CComplete connectivity, including a phono input, AM/FM radio, digital audio inputs (1 coaxial/2 optical), home network DLNA®, vTuner Internet radio, iOS Direct with built-in DAC (digital-to-analog converter) or audio file play via USB.
    Enjoy the merits of traditional analog components without sacrificing the convenience and precision of modern digital media. From capturing the sounds of your vinyl through an analog phono input to marveling at the programming available through your vTuner internet radio access, you get the best of both worlds – complete with all the connectivity and interactivity you demand from your various electronic devices. Network DLNA 1.5 and internet radio open the door on digital access while further interactivity is yours with iOS Direct through USB inputs.
    The Harman Kardon Remote app – available from the iTunes App Store for iOS® devices and the Google™ Play service for compatible Android products – extends the functionality of your system by connecting with your compatible smartphone or tablet to drive the HK 3770 – without needing to pick up the remote. It’s also the perfect tool to organize and play back your music from your mobile device and home network.
    Re: Harman Kardon HK3770AM-Z $315
    Originally posted by mikejennens
    That looks very nice, but I don't see something that would concern me.
    +1, nor do I get why this would be posted in a pro-sound forum.
    www.billfitzmaurice.com
