need ideas for a portable cabinet utilizing a Peavey blue Marvel 12 and other components. This would be used with a 120 watt power mixer for acoustic guitar and vocal mic coffee house gigs. Looking for portability and true acoustic sound for the guitar and clean smooth tone for vocals.
acoustic musician looking for a portable speaker cab build
Re: acoustic musician looking for a portable speaker cab build
If you are after a true acoustic guitar sound and clean smooth tone for vocals I personally would use a different speaker . i replaced the BM in my Peavey tube amp pretty quick ,
the eminence coaxial maybe ?
BFM's Simplexx 12 PA version would be perfect, uses the Eminence 12" Coax with an Eminence compression driver. DIY would run you in the $200-$250 range.
Currently resigned to living in balmy Zephyrhills, FL with the snow birds.
Howard H
Originally posted by zhillsguy View PostBFM's Simplexx 12 PA version would be perfect, uses the Eminence 12" Coax with an Eminence compression driver. DIY would run you in the $200-$250 range.
http://www.billfitzmaurice.com/Simplexx.html
Kevinr.................funny you said you replaced your BM from your Peavey tube amp, that is where this one came from. I actually have 2 that I replaced from my Dual 212 with Eminence Governors.............love em. I will check out the coaxial and drivers suggested in later posts....
