Guys, need some help here.
Situation:
Place:
Night club (volume is about 45'*50'*20' high).
Tops:
4 x passive CV 3-ways, 15"/6"/1" horn, 40 Hz Fb, good down to about 70 Hz
2 x Mackie active 2x15"+1" horn, unknown Fb, unknown F3
All wall-mounted about 6 feet up, facing down to the center of the dance floor.
Bass:
2 vented "W-bin" 18" horns, B&C drivers, vented @35 Hz, corner-loaded
Equipment:
Mixer->Aphex Aural Exciter->dBX compressor->DriverRack PA->amps + active speakers.
I found the DriverRack PA with the following settings:
Sub:
HP @20 Hz, 6dB/octave
LP @ 50 Hz, 12dB/octave
Gain: +8.5 dB
Mid (feeding the amp that's driving the CVs):
HP @200 Hz, 12dB/octave
LP @20kHz, 12dB/octave
Gain: -10dB
Highs (feeding the active Mackies)
HP @ 160 Hz, 12dB/octave
LP - passthru
Gain: -5dB
Does this sound "right"?
I've been in the club a few times and to me it's missing that upper bass "hit", and from those settings I think I might know why.
From the settings, it looks to me like:
1. The tops are crossed over way too high. Should be around 80 Hz or so. Maybe even lower, seeing that they're vented.
2. The sub's HP filter is way too low and shallow. Should be something more like 30 Hz @ 24dB/octave
3. The sub's LP filter is way too low - should be around 80 Hz, but adjusted to match where the tops start falling off.
4. Gains on all channels should be set to 0dB and the gains at the amps (and active speakers) adjusted accordingly.
Am I on the right track here? I may be heading down there tomorrow with my measuring equipment to see how I can help sort things out. BTW, any ideas on what sort of "house curve" I should aim for, when measured on the dance floor?
Situation:
Place:
Tops:
Bass:
Equipment:
Sub:
Gain: +8.5 dB
Gain: -10dB
LP - passthru
Gain: -5dB
