My girlfriends dad wanted me to check out a pair of bass cabs for him. The cabs are just a big sealed trapezoid around 200 Litres with cutouts for a pair of 15" drivers. The drivers are a mismatched bunch which I advised that its a bad idea to have mismatched speakers share the same air space, but right now am just looking for opinions on what to do with the parts available.
We have a pair of RCF L15P/06C 15" bass guitar speakers. These things have monstrous motors however the T/S leave a bit to be desired. I can make the pair work in one of these bass cabs fairly well by adding a port.
* f(s)= 24.90 Hz
* R(e)= 6.04 Ohms
* Z(max)= 165.50 Ohms
* Q(ms)= 4.183
* Q(es)= 0.158
* Q(ts)= 0.153
* V(as)= 290 liters
* X(max) = unknown
We also have a JBL K140. This is a nice speaker that may be 30 years old. Alnico magnet, T/S lines up to a nice large ported cab, however with not a whole lot of power handling before running into excursion limits (70W)
* f(s)= 34.99 Hz
* R(e)= 6.24 Ohms
* Z(max)= 125.30 Ohms
* Q(ms)= 7.004
* Q(es)= 0.367
* Q(ts)= 0.349
* V(as)= 230 liters
* X(max) = 5mm
We also have a JBL E140. Unfortunately this one is completely seized. It looks to have been reconed or at least repaired in the past, so I am wondering if its worth the expense to have it reconed again properly.
My recommendation at this time is to use the RCF drivers in one of the bass cabs, and sell the K140 and the other cabinet. What would you do with the above selection of parts?
* f(s)= 24.90 Hz
* R(e)= 6.04 Ohms
* Q(ms)= 4.183
* Q(es)= 0.158
* Q(ts)= 0.153
* V(as)= 290 liters
* X(max) = unknown
* f(s)= 34.99 Hz
* R(e)= 6.24 Ohms
* Q(ms)= 7.004
* Q(es)= 0.367
* Q(ts)= 0.349
* V(as)= 230 liters
* X(max) = 5mm
