DIY 18" Black High Gloss Subwoofer Enclosure
  • DIY 18" Black High Gloss Subwoofer Enclosure
    Finished 8-2-16. My first black High Gloss finish. All hardware purchased from Parts Express. Box is tuned to 38 Hz. Tuned with two Precision Port 4" Flared Ports - Part # 268-352. Driver is a Dayton Audio RSS 460HO-4 18" Subwoofer- Part # 295-472. Powered by a Crown XLS 1002 DriveCore 2 Power Amplifier, bridged for 1100 watts RMS @ 4 Ohms, Part # 245-507. Box Material is 3/4" MDF. Finish used was Rust-Oleum Gloss Black oil based paint, covered by oil based Polyurethane .
    Front View
      Nice job! But why such a high tune?
      http://www.diy-ny.com/
        To take advantage of the boost from the ported tuning, I could have tuned at 17 to 21 Hz for a flatter curve, but it is just my preference. My test revealed a pretty flat response curve, maybe because of room gain. See graph. I used a decible meter and tone generator - http://www.szynalski.com/tone-generator/ to get the results. Sounds great.
          Nice job on the finish! RS Subs are just soooo....sexy! It's gonna be a tough choice for me when it comes time, the Ultimax Subs aren't hard to look at either.
          My "No-Name" CC Speaker
          Kerry's "Silverbacks"
          Ben's Synchaeta's for Mom
          The Archers
          The Gandalf's
            Looks fantastic, for sure.
            Could I pick your brain on the amp a bit? That's the new Crown series that replaced the XLS series. I have the XLS1500 but needed to purchase a ART Cleanbox to get the RCA line level output from my HT amp up to Pro audio levels. I thought I read that the new Crown amps had built in switching for home/pro output built into them, is that true? Also, how do you like the amp in general? I like mine, but honestly I don't use it an awful lot, not as much as I wish I did. Thinking about possibly this amp or the 1500 for a friend's sub build.
            Thanks, and nice work on your project, it looks beautiful. Not many folks think to use oil paint.
            TomZ
              That's an easy to look at Sub...well done!
                TomZ
                Thanks TomZ. To answer your question about the line in switching. The new Crown amps have a high and low input sensitivity selection. Normal is 1.4V and High is .775. Default is the High setting that is recommended for RCA plug ins. I believe the .775 V setting gives a slight boost to the signal.
                As to how I like the amp, I believe it is well made and the features and programming is excellent. The style is OK, but function and performance is more important. It definitely is doing a great job so far.
                  Nice job on the finish! It looks great. Is there something reflecting in the cone of the sub in your last picture or do they have that sort of redish look to them?
                  See my projects on Instagram and Facebook
                    It's just a reflection. Probably from the curtains.
                      Was that Rust-Oleum spray or brushed gloss paint? Great job man!
                        9 cu.ft. ?
                        Personally, I'd have tuned somewhere in the lower half of the 20s.
                        Great job!
                          Thanks DKKruse. Paint and Polyurethane was applied with foam brushes. no sanding needed.
                            Hm, I also find the tuning odd, but it looks quite sharp- what frequency are you high-passing at? 3/4" walls? If so, I'd suggest squeezing a few more dowels in there if you can. The black look certainly is attractive!
                              I am using a low pass starting at 250 HZ. I have a DIY 15" dual voice coil sub that was tuned to 33 HZ in my SUV and this one sounds even better. Id say even though 38 HZ tuning may sound a little high, hearing is proof when I compare it to other subs that were suppose to be tuned to 17 - 21 HZ for a flatter response curve. the 45-50 HZ range has more acoustical energy. Of course this is just my opinion and there may or may not be any data to support that, and as I said, this is my preference in bass frequency.
