Thanks for all the extra effort, Don!
Trump Tower build
Originally posted by Pallas View PostI'm still trying to figure out the name reference. Are you going to gild the cabinets and stuff them with excrement or something, i.e. turn them into some performance art piece?Your results may vary.
Originally posted by mattp View Post
I'm not sure why you think this is OK to post but consider yourself warned.
Tangband W6-sub
I clamped half of a panel at a time.
Tip for beginners: Rather than clamping both ends then the middle, etc. It is easier to get all the work pieces aligned if you start at one end, then work your way down toward the other. I clamped downward for alignment, then placed a clamp very close to the caul and clamped the strips together. Then, moved the caul and did it again - always clamping close to the caul.
Two halves clamped.
I now have four Mahogany side panels ready for the router template.
- Likes 1
Do you use biscuits or dowels or do you find them unnecessary when using the cauls?
Originally posted by Kevin K. View PostDo you use biscuits or dowels or do you find them unnecessary when using the cauls?
Thanks again for some great assembly tips.
I never thought about sliding the caul down the length, clamping as I go.
But I always thought that a good caul needed to be on both sides.
What is under that caul that you are clamping to?
Tangband W6-sub
Originally posted by donradick View PostWhat is under that caul that you are clamping to?
- Likes 1
Wow, those mahogany boards look beautiful!
they are going to make the whole visual impression pop.
Tangband W6-sub
- Likes 1
Thanks, Don!
One of my wife's friends has a daughter who is getting married very soon. I was asked to make this for the occasion. The Cross is Walnut, as is the G, on an Oak plywood backing, surrounded by a Mahogany frame. I cut a Keyhole Slot in the back to facilitate hanging it on a wall.
- Likes 1
Dan, I'm looking at that last photo and the reflection of the "G" is pretty impressive. Could you share your process and finishing materials for the sidewalls? Also, did you polish them? Thanks.
