Hey PassingInterest - you might want to hold up on that crossover work.
I think I posted several weeks ago that the 10 degree lean back would require
a crossover tweak at minimum, and maybe more. Working on that aspect now.
Trump Tower build
Originally posted by Pallas View PostI'm still trying to figure out the name reference. Are you going to gild the cabinets and stuff them with excrement or something, i.e. turn them into some performance art piece?
- 1 like
I wanted to drill all the boards at once to save time.
I put the tweeter circuit on a separate board to make sure I wouldn't have a close proximity issue with cross-talk induction between the tweeter's coil and the ones for the woofers. The components are soldered. I just need to add the wires and use some hot melt glue.
- 1 like
Dan I'm just getting caught up on some threads, great woodworking, thanks for posting the detail!
Javad
- 1 like
Originally posted by donradick View PostI know you are super thorough in your planning - what will you do for feet?
- 1 like
Thanks, Don! We all help each other in this hobby.
I wanted to use up some automotive primer I had in the garage. I did. It's gone. So, from this point, I will spray/sand/spray/sand some water based polyurethane, until I fill the grain and get the surfaces smooth. Then I will paint them black.
Interesting method to trim the top flush.
In retrospect, it's obvious since the top is not a 90 degree angle.
I learn something from every post you make.
The 3 pair look incredible!
- 1 like
Now to trim the top flush with the back and the bottom edge of the baffle flush with the cabinet bottom. I already started, before I got the idea to stop and get a picture.
Rather than plunge all the way down to the surface, I rest the bit on a thin piece of cardboard. After I route, I will have just a little bit to sand flush.
After some sanding.
- 1 like
Installing the front baffles.
I just rocked the cabinet and rolled through the curve to trim the baffle flush with the sides.
Thanks, Kevin! I always think that I move way too darned slow on my projects. At the end of each day, I think, "I know I was busy all day, but is that all I got done"?
I've got a couple more pictures. I'll post them tomorrow.
