Sonic Barrier Acoustic Panels
  • Sonic Barrier Acoustic Panels
    Due to my recent upgrades I decided to hang some foam panels up on the wall to help with reflections I was getting in my somewhat square room. I used our new Sonic Barrier foam and command strips to hang them. There is a noticeable difference. There was no rhyme or reason to where I put them, I just wanted something around tweeter/head level.
    Ignore my existing furniture, that stuff will be replaced in a couple weeks. UM18 boxes make for good end tables though...
    Your results may vary.
    Love the make shift coffee table and chair, been there, done that. Man I can only imagine the bass response in that room, it's gotta be crazy good.
    ​Is there an adhesive on the panels for hanging them or did you use a different method?
    My "No-Name" CC Speaker
    Kerry's "Silverbacks"
    Ben's Synchaeta's for Mom
    The Archers
    Rick's "db" Desktop CBT Arrays
    The Gandalf's
      I like the chair and cardboard box table as it's similar to what I have. Nothing but the best for decor.
      The elephant in the room is the room
        Kevin,
        I used basic command strips to hang these, just two strips on each panel in the top corners. They work really well. And yes...the bass response is a bit ridiculous. I'm still tweaking here and there but it's getting dialed in. The room is 11x12ish. I would genuinely be worried if I tried maxing these subs in this room. I have found the resonant frequency of my floor is about 7 Hz
        Damn skippy. My new stuff will be here in two weeks, I can't wait. That bag chair isn't the most comfortable thing (hence the pillow).
          [ATTACH=CONFIG]n1371177[/ATTACH]
          [ATTACH=CONFIG]n1371178[/ATTACH]
          [ATTACH=CONFIG]n1371179[/ATTACH]
          [ATTACH=CONFIG]n1371180[/ATTACH]
          Matt is there a general rule of thumb as far as placement and the amount needed?
            Are those curtains leather
            Craig
            I drive way too fast to worry about cholesterol.
              ​I thought I saw some handcuffs and maybe some cattails. Is this a fifty shades of subwoofer room?
                Is that a woofer/clock on the right side behind the speaker?
                I AM stealing that! (The idea, I mean)
                Zarbo Audio Projects Youtube Channel: https://www.youtube.com/channel/UCEZ...aFQSTl6NdOwgxQ * 320-641 Amp Review Youtube: https://youtu.be/ugjfcI5p6m0 *Veneering curves, seams, using heat-lock iron on method *Trimming veneer & tips *Curved Sides glue-up video
                *Part 2 *Gluing multiple curved laminations of HDF
                  There are guidelines using Sabine's formulas, considering angle of incidence.
                    While I know this is an older thread, in response to Tom-
                    Yes- it's a woofer clock. Matt had a bad HiVi D8.8+ a while back. It has 12 mounting holes, and he asked what to do with it instead of throw it out. I suggested a clock, and he documented how he assembled it to look the woofer was still a functional piece without having the magnet still inside the frame. What he did was quite slick!
                    *InDIYana event website*
                    Photobucket pages:
                      The UM18's give a new meaning to the 'elephant in the room'....Is there any information on the other speakers you are using?
