Greetings all,
This will be my >$200 entry this year at MWAF. I brought the partially complete speakers to InDIYana and they were well received. Thanks for all the positive feedback. Someone asked me if these were the "Totally Flat" speakers that I had built last year. They look similar, but are completely different; new box, new drivers, new crossover.
Based on feedback, I will be revising the crossover to reduce the woofer level by about 1dB. It may have been the room, but the woofer seemed just a little too overpowering, masking the detail just a tad in the mid and high frequency areas.
Driver selection:
Tweeter: Peerless DA25TX00-08 (8 ohms) (see pic). This is the poor man's high end tweeter, with sound quality comparable to some of the very best tweeters available, regardless of price.
Midrange: Tang Band W3-1797S 3" aluminum sandwich full range (4 ohms) (see pic). This driver has the midrange clarity and detail of a good planar type driver, such as the B & G Neo-8 or Neo-10. TB also makes a 4" version of this driver, but I decided to go with the 3" because it has 20% less cone mass. Power handling will be a little less than the 4" version, but it should be able to hit my goal of roughly 95dB in the listening chair with both speakers playing.
Woofer: Tang Band W6-1139SIF (4 ohms) (see pic): I wanted to keep baffle and cabinet size to a minimum, yet have a system that could dig deep with authority. This subwoofer can go right down to 25Hz in a very small box (3/4 cubic foot or so). The trade off is efficiency, which should be OK as long as I use an amplifier with sufficient power that can handle the load.
Impedance: The mid and sub are both 4 ohms, which causes the overall system Z to dip to about 3.5 ohms at 600Hz. Phase angle, however, is zero at this point. The amplifier output stage will get very warm but this should not be a major problem.
Efficiency: Probably somewhere in the 83dB/1W/1M area, which is quite low. Again, a big power amp that can handle a 4 ohm load will be necessary.
Progress: I am currently working on re-painting and re-finishing the box. I'm also replacing the particle board xover box with a much improved hardwood unit. And I just put in my parts order for a couple crossover revisions.
Next up: A few historical construction posts. I started building these about 4 months ago and am now approaching the finish line. In the next few weeks, I'll finalize & post the completed xover, cabinet, and FR measurements. Comments and questions are always welcome.
Driver selection:
